Originally posted by dlacouture GoremanX, could you try the same with SR off? Or at least find the slowest speed you can achieve without SR?
Just to know how many stops we are really talking about here...
With my 200mm, I'm able to go from 1/30 (SR off) to 1/5 (SR On), with about the same success rate (about 75% sharps). That's nearly 3 stops...
I just took 90 pictures at different shutter speeds with SR on and off to see how much improvement I really get out of it.
For all of these, I was standing about 30 feet from my subject, which was fairly well lit with 2 x 100watt equivalent CFLs and 1 x 60watt equivalent CFL. All shooting was done at ISO 800, and for every stop of shutter speed I added, I removed one stop of aperture. My stance involves having both elbows resting against my chest, aiming carefully at a spot, half-pressing the shutter to auto focus, waiting for the SR icon to come on (if SR is turned on), and then gently pressing the shutter button the rest of the way to take a picture. My left hand is holding the lens by its zoom ring, and my right hand is holding the camera's body, with my thumb under the camera to help keep it stable when I press the shutter button with my index finger. I aimed at a slightly different spot of my scene for each shot, and always re-focused.
The camera is a K-7 with firmware 1.03. The lens is a DA* 50-135mm set to 135mm. I took 9 pictures at each setting to see how many of them would turn out "good". Why 9? Because that fills up a 9x9 grid on the screen in playback, which made it easier to keep count. I only counted the ones with excellent sharpness as "good". Any amount of visible camera shake meant I didn't count that picture. The scene I picked included a lot of text, which made it easy to determine how much camera shake was present.
Is that description detailed enough?
Here are my results:
SR Disabled
1/100 and F2.8 - 7 good (always out of 9)
1/50 and F4.0 - 3 good
1/25 and F5.6 - 1 good
1/13 and F8.0 - 0 good
1/6 and F11 - 0 good
SR Enabled
1/100 and F2.8 - 8 good
1/50 and F4.0 - 8 good
1/25 and F5.6 - 8 good
1/13 and F8.0 - 4 good
1/6 and F11 - 3 good
These 90 photos span 5 different shutter speeds and 4 full stops. I think those results are pretty good, they certainly show SR in a positive way. And they're much better than the results I used to get with the old firmware. I couldn't get so many good pictures at 1/6 before, especially not at 135mm.
Here are a few 100% crops of the shots that I considered "good" (remember I was always focusing in a slightly different place):
(that far right one is borderline, that was the worst of the "good" ones)
And these are 100% crops of some of the shots I considered "bad":
This is the scene I was shooting, aloways focusing somewhere on the box to make sure the text was in focus:
