07-04-2007, 02:44 PM   #1
hinckc's Avatar
How to -- 2 flashes 1 exposure
Hi all,
I think I've done this before, so I'm relatively certain it's possible.
I've got a K100D and one of each af360 af540fgz. However, I'm pretty sure I didn't have my 540 the last time I did this, so I think it was just my shoe mounted 360.
I know I've setup a shot that fired 2 strobes in a single exposure. But I can't figure out now how to set everything up.
When I've done it in the past, I got one flash fire at the very beginning of a long (1-3 second) exposure, and then a second fire of flash at the beginning of the travel of the second curtain.
The only thing I might be thinking is that last time I was just using P-TTL - trailing curtain, and the leading edge flash I thought I saw was actually just the pre-flash, and trailing one was, well, the trailing curtain flash.
Is this the only way it's possible? Anyone know how to do this?
Thanks for your help!
-Chris
07-04-2007, 07:33 PM   #2
hinckc's Avatar
heh... I think I've figured it out. I was right in my last guess.
I'm now set to Tv mode, with my 360 shoe mounted, and set to P-TTL mode, trailing edge sync.
I've set a 10s exposure.
Now when I click the shutter, it fires the flash once, but apparently it's before the shutter opens, not after. Then, leaves the shutter open for 10 seconds, and fires the flash again, at the end of the exposure. So it is firing 2 flashes, but only 1 during the exposure.
I guess to do what I really wanted to do, I'd need to do more reading about using manual flash, since I could probably fire 2 flashes manually via the "test" button, or something similar.
Thanks for reading!
-Chris
camera, curtain, dslr, exposure, fire, flash, photography, time
K-7 Video Frame Exposure Errors "flashes in video" steveoliver Video and Pentax HDSLRs 4 06-02-2010 07:36 AM
flashes jolee1990 Troubleshooting and Beginner Help 21 05-22-2010 10:29 PM
Flashes on my K-m Sasquatch Pentax DSLR Discussion 2 01-12-2010 09:43 AM
What other camera co's flashes can use the same addons as my Pentax flashes? Grimlock Flashes, Lighting, and Studio 3 08-22-2008 05:39 PM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
All times are GMT -7. The time now is 11:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
