02-26-2010, 07:11 AM   #1
adwb's Avatar
exposure changes when shutter pressed?
I suppose this has always happened but I have never noticed it and can you stop it?
On a K10 set to manual mode when I set for example f11 and 1/1000 now I can see the exposure bar is about 1.75 stops underexposed but I want this, but when I press the shutter the camera changes the setting to F13 and 1/1250.
Now that takes a image which is in fact not too badly exposed ;although not what I would get if I pressed the green button which in this case gives me f10 and 1/250
In fact if I release the shutter button the speed I set is still in the view finder but the aperture has stayed at 1/1250
So how do I get the manual mode to do what I want and not what the camera wants
Alistair
02-26-2010, 07:36 AM   #2
sterretje's Avatar
I could not simulate it with either a FA31 or a DA18-55 on a K10D; but you might be using a M42 lens or so. Can you tell us which lens you're using and the exact sequence of steps?
02-26-2010, 07:50 AM   #3
adwb's Avatar
duh me stupid, I had set AE-L with AF locked set so as soon the camera focus of goes the exposure setting.
It is interesting however that in manual mode if set like the above that happens and the exposure is fine but not what the green button [set in program line] wants to suggest.
Alistair
02-26-2010, 10:34 AM   #4
Marc Sabatella's Avatar
Assuming by "manual mode" you mean the "M" exposure mode, there is absolutely no way the camera should change anything when you press the shutter, regardless of any option setting I can think of. Only the Green button would cause the camera to ever change expsoure in M mode. Perhaps you mean you were in manual *focus* mode, but your exposure mode was P or something else automatic?
02-26-2010, 06:15 PM   #5
adwb's Avatar
Assuming by "manual mode" you mean the "M" exposure mode, there is absolutely no way the camera should change anything when you press the shutter, regardless of any option setting I can think of. Only the Green button would cause the camera to ever change exposure in M mode. Perhaps you mean you were in manual *focus* mode, but your exposure mode was P or something else automatic?
nope, I meant manual exposure mode, what I described is with a auto focus lens
and my k10 definitely changes what you set when you press the shutter button and thus trigger the meter which if linked as described before causes the manual setting to be overridden. if you disable this setting [which is the default setting]
then manual works as expected. I have not tried this with a manual focus lens yet but will and revert with the findings.
Alistair
button, camera, changes, dslr, exposure, mode, photography, shutter
Well I pressed the button and bought an EOS 7D Big G Non-Pentax Cameras: Canon, Nikon, etc. 48 04-01-2010 01:51 PM
Exposure: Shutter Speed, Aperture, ISO ltdstar Photography Articles 0 06-05-2009 06:27 PM
Running Water: Slow Shutter and Fast Shutter Comparison Mike Cash Post Your Photos! 2 02-03-2009 01:25 AM
P30T, shutter will not reliably stay open on bulb with cable shutter control. skid2964 Pentax Film SLR Discussion 6 06-09-2008 08:04 AM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
All times are GMT -7. The time now is 05:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
