03-02-2010, 10:51 AM   #16
QuoteOriginally posted by aleonx3 Quote
he thinks the Canon 5D MKII can do everything intelligently than my K10D can. .
Although "Face detection" software is becoming better, this ONLY works when you are using Contrast-detection AF, which reads the data OFF the sensor. In DSLRs, you have to be in LiveView mode to get CD AF, and it's PAINFULLY slow. You generally use Phase-detection AF, which uses seperate sensors and is done before the mirror flips up. These sensors ONLY detect contrast, and can't tell a face from a tree branch. And there are only a discrete number of them, so the AF system can NOT look at the entire scene and determine WHAT the subject should be.
Your friend needs to get a reality check. He probably should have stuck with a Rebel (I own the Xsi, it's a fine camera, but I do NOT put it in AUTO )
camera, dslr, focus, photography
Linking AF point and AE during multi-seg metering geckogrin Pentax DSLR Discussion 3 08-21-2010 07:59 PM
Manual Focal Point adjustment- K20D heaven72501 Pentax SLR Lens Discussion 5 03-14-2010 01:06 PM
I don't get this multi point af stuff...... kace Troubleshooting and Beginner Help 19 01-19-2010 11:09 AM
Setting up focal point for manual lenses. consider crop factor? D4rknezz Troubleshooting and Beginner Help 7 09-23-2009 01:00 PM
k10d multi-point focusing samiam Pentax DSLR Discussion 12 01-03-2008 02:37 PM
All times are GMT -7. The time now is 12:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
