Originally posted by Ira If you tried to print the uncleaned image on a web or offset press, you would get mud because of the screen--and usually very coarse for newspaper.
BTW:
Is there anything about this photo that's supposed to be dramatic, or is it just here as an example of noise?
I applied more noise removal to the streets then the vehicles and chopper since details on the street is not the focus point. You can always control how much noise you want to remove. It's all up to you at the end, The point is noise can be removed. High iso images when needed is not necessary a bad thing.
As for the smudges when printing. This is not true. I tried it with both a laser and inject printer, both came out as you see it in the photos.
