03-05-2010, 07:01 AM   #1
Sigma 600mm on Pentax *istDs
Hi
I have just purchased a Sigma 600mm F8 mirror lens to use with my Pentax *istD S. But I do not seem to be able get it to work. My other manual lenses (50mm and 135mm) work so assume that it must be something to do with the fact that the Sigma is fixed aperture.
I found this post
https://www.pentaxforums.com/forums/pentax-dslr-discussion/45132-sigma-600mm-...-new-k20d.html
but this relates to the K20D.
Is there any way to get my Pentax *istD s to work with this lens?
Thanks.
03-05-2010, 07:07 AM   #2
Manual mode, meter with green button. It should work no problem. I use a similiar one on my DS.
And yes, you have to allow aperture ring use.
03-05-2010, 08:28 AM   #3
Sigma 600mm
Sorry some questions
Manual mode
OK understand this
Meter with green button.
I don't understand this. Can you explain?
How do I this?
My camera is a Pentax *istD S.
Thanks
03-05-2010, 08:35 AM   #4
Jools's Avatar
green button
You might want to take a look at the top stickys in the beginner's corner Q&A forum for some info on the green button usage. There some real good stuff in there.
03-05-2010, 08:39 AM   #5
sterretje's Avatar
It's a function of the camera. I doubt however that your camera has it. On the bK100D (which does not have it), it's an item in the custom menu that relates to AE-L and M mode that gives the same functionality
How do I this?
Again an item in the custom menu on a K100D
So read the manual is the first suggestion.
03-05-2010, 09:01 AM   #6
OK, my bad. I'm talking about the AE-L button when I say green. Does the same thing.
Aperture ring. Go to the custom menu, scroll down till you see "using aperture ring". Set it to #2.
That's all you need to do. Now put it in manual mode, focus, press AE-l button, push shutter button. If it is too light or dark. You can use the thumb wheel to change shutter speed.
03-05-2010, 09:08 AM   #7
Just1MoreDave's Avatar
With this lens, just skip all that metering stuff. It's only got one aperture, f8. So although you don't get an aperture readout in the viewfinder or top display, the lens works fine in all modes.
03-05-2010, 11:50 AM   #8
Thanks. Working now.
03-05-2010, 12:00 PM   #9
Miserere's Avatar
I generally shoot mirror lenses in Av using EV comp. to taste.
03-05-2010, 02:07 PM   #10
Ben_Edict's Avatar
QuoteOriginally posted by Just1MoreDave Quote
Exactly. No need for Green Button and M mode at all. Av etc. works fine with a fixed aperture lens.
Ben
*istd, 600mm, camera, dslr, lens, pentax, photography, sigma, sigma 600mm
For Sale - Sold: K10D, *istDS, Sigma 17-35mm 2.8, 28-200mm, more awsutter Sold Items 28 02-19-2009 10:33 AM
Sigma 600mm Mirror on a new K20D CraneGuy1 Pentax DSLR Discussion 11 01-09-2009 08:21 PM
Pentax 600mm f/4 vs Sigma 500mm f/4.5 crttr Pentax SLR Lens Discussion 20 09-10-2007 07:13 AM
Sigma 600mm/8 for istDs? Arpe Pentax SLR Lens Discussion 10 11-16-2006 03:57 PM
All times are GMT -7. The time now is 06:06 PM. | See also: NikonForums.com, part of our network of photo forums!
