03-05-2010, 08:15 AM   #1
Deiberson's Avatar
what do you set the sharpness and saturation to?
should i be changing my sharpness and saturation levels on the menu or is the general consensus to leave the default @ 0?
03-05-2010, 08:30 AM   #2
I would think most people adjust sharpness in PP.
03-05-2010, 08:40 AM   #3
Pauld's Avatar
QuoteOriginally posted by cinaibur Quote
I'm with you on this one. I leave sharpness, saturation and contrast all set at 0 and handle all in PP.
03-05-2010, 08:41 AM   #4
Zero. I do all my adjustments to the RAW files in post processing.
03-05-2010, 09:00 AM   #5
Ira
Just started using my KX, and since I'm just doing JPEGS now--and the camera's processing has been so highly reviewed--I've been using Bright as +1 on both sharpness and saturation.
In time, I'll learn to realize and visualize all I can do in PP, but for now, I want to give the out of camera image a little edge, and plus one ain't no big deal.
03-05-2010, 09:17 AM   #6
I would still be capturing RAW files. Once JPG settings are set and the files are made, it can be difficult (not impossible) to undo.
03-05-2010, 10:26 AM   #7
Ira
QuoteOriginally posted by JeffJS Quote
Believe me--I hear where you're coming from. But it's only been a week and I haven't exactly been capturing any mind-blowing visuals yet anyway.
I also need to buy a new and larger card.
03-05-2010, 10:42 AM   #8
grey goat's Avatar
I shot JPGs with my K-7 for a few days, too, just to get a fell for the camera. I was glad to switch over to shooting DNGs.
I don't know where I'd set everything in-camera, but for saturation, I think I'd go with natural. At least that's what seemed right to my eye with the K-7 in the few days I shot JPGs.
A new, bigger, faster card might be just the thing to get you started shooting in RAW, Ira. But don't rush: get to know the K-x first.
Enjoy!
03-05-2010, 12:10 PM   #9
Itai's Avatar
Honestly, find the settings that look right to you. Whenever I get a camera, I try all the settings and pick the ones that give the most natural results. I use a color-chart and such but you can eyeball it. The importance is the result. With the K-7, I find Saturation +1 and Fine Sharpness 2 +3 to give the best results.
Here I even did the K-7 sharpness test for everyone to try all 27 settings:
Pentax K-7 Image Sharpness | Neocamera.com
When trying out, make sure you look at both soft (the fur) and hard (the writing on the buttons) details.
- Itai
Neovoyage | Explore, Experience, Expand your horizons | Travel Photography
03-05-2010, 03:30 PM   #10
Clicker's Avatar
All at their weakest/lowest other than off.
03-06-2010, 05:20 AM   #11
adwb's Avatar
QuoteOriginally posted by Deiberson Quote
On my K10 all at centre except the sharp which is on max.the saturation and contrast are best left for PP.
I have found that either raw or jpeg if i pixel peep at a straight edge there is large difference to the jagged edge effect that is visible with it off and on. I also found that in pp regardless of which brand and which sharpening method applied there was no improvement over using the in camera one.
all this experimenting was done by me for my images long ago and I have used these settings both on a K100d and the k10 for a couple of years and see no reason not to. maybe it is my lenses or my head lenses??
Alistair
03-06-2010, 09:27 AM   #12
philbaum's Avatar
I've read that its best to have contrast set to minimum so that the camera can capture the most information available without clipping, in all situations. I noted that the OP didn't ask about contrast, wondering what other folks thought about contrast.
The others i set to natural and zero, adjusting during pp for only those that i work on.
03-06-2010, 09:58 PM   #13
MSM
MSM's Avatar
QuoteOriginally posted by philbaum Quote
Philbaum: I have read the same thing elsewhere. I can't remember where. The gist was to set both the contrast and the saturation to a minimum if you are shooting RAW. The file you see on the LCD is a jpeg which uses your settings to generate a histogram. If you use this information to guide your manual metering or EV compensation you may be misled. More specifically, turning up the contrast and/or saturation may push the histogram to the right. This may in turn make you dial down the exposure, thereby underexposing. If you like to ETTR and shoot RAW, keep the settings to a minimum is what they say.
03-07-2010, 07:11 AM   #14
i shoot with contrast,saturation and sharpness to negative possible. later adjust it to my taste in cs or in lightroom.
camera, dslr, photography, saturation, sharpness
K5 - How do I access "Custom Image" to change sharpness/saturation/contrast, etc ? Feudal1 Troubleshooting and Beginner Help 3 11-03-2010 06:38 AM
Sharpness VS Fine-Sharpness in k20d wasim_altaf Pentax DSLR Discussion 8 10-12-2009 11:41 AM
Sharpness vs Fine Sharpness on K20D morfic Pentax DSLR Discussion 2 11-02-2008 10:13 AM
Fine sharpness and sharpness move together on K20D 1.01 morfic Pentax DSLR Discussion 2 07-11-2008 09:18 PM
Do you customize the Sharpness, Contrast and Saturation settings on your DSLR? lastdodobird Pentax DSLR Discussion 12 01-30-2008 07:41 AM
All times are GMT -7. The time now is 01:30 AM. | See also: NikonForums.com, part of our network of photo forums!
