04-08-2010, 02:23 AM   #16
The K-x, afaik, comes with the DA L. Although the DA II is claimed to be better, I remember even compared with DA I there were reports of samples that defied this rule... I think overall DA II should be improved, and DA L and DA WR should be optically the same. Sensors doing the differentiation maybe?
Construction wise, the DA WR would be the best, DA L probably the not as great because of the mount.
04-08-2010, 02:27 AM   #17
jct us101's Avatar
QuoteOriginally posted by edumad Quote
But the DA L and the DA II are the same lens, just in cheaper packaging, right?
04-08-2010, 04:25 PM   #18
GerryL's Avatar
QuoteOriginally posted by jct us101 Quote
Cheaper packaging since it has a plastic mount, it doesn't come with a hood.
It also doesn't have measurement markings (infinity to 55mm) and also doesn't have the clutch focus..hmmm, did I miss anything else?
I would rather go for the DA 18-55 II as it is actually affordable and you don't have to scrounge for the hood through any other maker or seller as this is usually the case for most that have the DA L lens, they always end up buying or looking for the lens hood.
04-08-2010, 08:01 PM   #19
Most definitely, the second version is a little bit sharper and has a little less distortion, but most importantly the vignetting is gone. That was the one thing that annoyed me most about that lens too.
Ditto. I was surprised how much improved the vignetting issue was from mk I to mk II.
Both copies I've had of the DA L have been noticeably better than the original DA 18-55.
04-08-2010, 08:13 PM   #20
er1kksen's Avatar
The II, L, and WR versions are optically identical, as noted, but there may be some quality control differences. The II I used on my K20D was much sharper than the L that came with my K-x. It seems I got a less-than-perfect copy of the L. The IIs and WRs may be manufactured with tigher tolerances than the cheaper-built L. If you get a good one, though (and most I've heard of are), it's a darn good lens for the price.
04-08-2010, 08:28 PM   #21
QuoteOriginally posted by er1kksen Quote
That's an interesting point. I wonder if Pentax can "bin" lenses (or lens elements), the way that Intel and AMD bin CPU's.
04-09-2010, 08:12 AM   #22
GerryL's Avatar
I think that the 55-300mm DA L have more success on this than the 18-55mm DA L.
These lenses are actually a good deal the the more expensive DA 55-300mm.
04-10-2010, 02:39 AM   #23
Also better contrast - I've used both lenses and can confirm this.
The new kit lens (V2) is an improvement on V1 and is about the best kit lens of the three top brands of DSLR (excludes Sony and Olympus as these are not the topmost brands :-))
18-55mm, camera, dslr, generation, photography
A Comparison of 1st & 2nd Curtain Sync Flash dosdan Accessory and Memory Articles 2 07-25-2011 12:27 PM
Nature Pentax takes 1st & 2nd place in 2 classes at VLF competition!!! (4 images total) Marc Langille Post Your Photos! 55 10-28-2009 11:17 AM
Photo of the Week - 1st Generation Pentaxian Adam Post Your Photos! 4 08-25-2009 06:45 AM
2nd Generation Pentax User cdeakin Welcomes and Introductions 6 08-03-2008 07:18 AM
1st and 2nd POTD, last month jsundin Post Your Photos! 6 04-09-2007 07:33 AM
All times are GMT -7. The time now is 08:24 PM. | See also: NikonForums.com, part of our network of photo forums!
