Originally posted by FlashCube Perhaps I wasn't clear. Did you not see where I said the photo browser Pentax supplies with their bodies can often name the Pentax lens used?
Yes, I saw that and my reply was
"I don't think OP has the camera yet".
Originally posted by FlashCube Furthermore, this is what the OP said:
"K-7 Doesn't Recognize the 18-55 WR Kit Lens"
If he opens up an image with the PhotoBrowser that comes with the K-7, I'd bet it will name the lens at least as a Pentax 18-55mm II.
I would not bet on it. My reply to the statement was
"And as I stated in my other post, no guarantee that it recognizes the lens as the lens might be newer than the software". I agree that it's very likely (as a K7/18-55WR/software has always been intended to be a kit and therefore it is
probably tested for that), but I also gave a reason why it might not be the case (post #11).
In my opinion you started mixing things / confusing the matter in
post #9 and that was the reason for my reply to you on that post. Below some quotes from that post and replies to the specific statements.
Quote: Why would the software be newer than the lens given there is an update on the firmware available for the K-7.
I never stated that the software would be newer than the lens; I stated that the lens could be newer than the software. In which case the software might not 'recognize' the lens (I posted my experience with this in post #4). Further in one sentence you use the words
software and
firmware update and there is (usually) no relation between the two unless there is a change in communication protocol.
Quote: Plus, older bodies like the K20d recognize the 18-55mm WR.
You confirm here OP's misunderstanding/misconception that bodies recognize lenses; this implies that you also don't understand how it works.
Quote: On the other hand, if the OP doesn't have the K-7 yet, how does he know it won't recognize the lens?
As explained, he used another tool; you could have figured that out by reading OP's opening post.
WimS
