Originally posted by ricstew ok so if I focus on the jump that I know the horse will go over say the top rail.......its actually not exactly where the horse will be............so it wont be in focus? Is it this hit and miss?
If you focus on the rail, you'll take a picture of the rail (unless the focus point you're using isn't aimed at the rail). Instead, focus on the rail, and then turn the focus ring counter-clockwise a tiny bit to focus just slightly in front of the rail, and aim your focus sensor where the horse's head will be. If you're lucky, you'll get it.
Problem is, catch-in focus doesn't often react that quickly. I've missed more shots than I've caught using this technique. It's a learning experience, you won't be good at it right away.
