03-10-2010, 11:13 AM   #1
tpeace's Avatar
K7 High Speed Continuous Shooting
I discovered that High Speed Continuous mode is pretty limited when the two Lens Correction menu options, Distortion Correction and Lateral Chromatic Aberration Correction, are set to on. The number of continuous shots is essentially reduced to one third.
With these options off, I'm getting 15-20 shots before the camera's processing buffer fills up and the camera begins to hesitate. With them on, it hesitates after 4 to 5 shots.
This isn't too surprising since these options obviously require more processing during the save operation.
Since I shoot sports and want to use the high speed mode, guess I'll just need to get smarter regarding the conditions when these settings are really necessary and make the necessary trade off accordingly.
re-t
03-10-2010, 11:31 AM   #2
I think most of people do these corrections in post processing.
03-10-2010, 11:56 AM   #3
Wheatfield's Avatar
I think most of the people who worry about this sort of thing need to go out into their back yards and try to figure out which rock they left their life under.
03-10-2010, 01:05 PM   #4
jpzk's Avatar
Suggestion only:
shoot RAW and do the corrections during PP.
JP
03-10-2010, 02:04 PM   #5
whoops......wrong post
03-10-2010, 02:46 PM   #6
GoremanX's Avatar
QuoteOriginally posted by tpeace Quote
I discovered the Earth is not flat.
03-10-2010, 04:18 PM   #7
Wheatfield's Avatar
QuoteOriginally posted by GoremanX Quote
I could have told you that, but you probably would have ignored me
03-10-2010, 04:20 PM   #8
Arpe's Avatar
Yes it takes way longer to save a file when those are turned on.
03-10-2010, 04:24 PM   #9
GoremanX's Avatar
I NEVER ignore anyone, I just discredit them and mock them and then belittle whatever else they have to say. THAT's the Canadian way!
Another signature banned? I saw nothing wrong with it!
03-10-2010, 07:08 PM   #10
hcc
hcc's Avatar
re-t
The topic of continuous shooting was discussed in other threads: for example https://www.pentaxforums.com/forums/pentax-dslr-discussion/87505-k-x-continuo...g-problem.html. Let us go back to the basics.
If you do continuous shooting (Hi), the optiumum setting are:
- remove all post-processing (especially lens correction) in your camera settings; extremely important because the PP slows down the writing speed; Do check that lens correction is Off
- use a good SD card; for example a Class 10 30 Mb/s; in continuous shooting [Hi], you will need have 5 files per seconds to transfer to your card;
- do not saturate the buffer: select a file format (and size) that allows you some continuous shooting without saturating the buffer; for example, with a class 10 SD card, ensure that the file size is less than 6 Mb to achieve 5 fps; I use myself JPEG 6Mp [***] file format with my Sandisk SD class 10 card;
- do not use RAW in continuous shooting [Hi]: you will fill up the buffer after a couple of shots.
- you must set the camera in AF.S or Manual focus during continuous shooting [Hi]. Do not use AF.C.
These basic guidelines are used by every serious "continuous shooter". It is correct that you may need to correct for lens distortion and a simple software like PTLens does a great job, especially when you have a large number of photographs.
03-11-2010, 04:44 AM   #11
bfo
QuoteOriginally posted by hcc Quote
Could you please explain why?
03-11-2010, 05:50 AM   #12
hcc
hcc's Avatar
QuoteOriginally posted by bfo Quote
In AF.C, the camera will continue to adjust the AF continuously: the processing will slow the camera and you will not not achieve 5.2 fps in [Hi] mode.
03-11-2010, 06:55 AM   #13
Mike.P's Avatar
Just as a matter of interest is that with all makes or just Pentax.
I would have thought AF.C is when the high fps would be most needed.
03-11-2010, 08:07 AM   #14
Wheatfield's Avatar
QuoteOriginally posted by Mike.P Quote
I think the higher end Nikons and Canons dedicate a processor to AF so that AF performance isn't compromised as much.
03-11-2010, 04:21 PM   #15
Arpe's Avatar
I read that one of those two, C or N or maybe both, you can choose focus or shutter priority. So it'll either only fire when focus is confirmed, or just fire away even if not in focus.
camera, correction, dslr, mode, options, photography, shots
Continuous shooting fekish Pentax DSLR Discussion 8 09-24-2010 05:58 AM
K-7 Continuous Shooting brosen Pentax DSLR Discussion 17 08-29-2010 06:24 PM
Shooting high speed objects at close range bymy141 Photographic Technique 9 08-25-2010 05:59 AM
My SD card cannot keep up to speed for Pentax K-X HI Continuous shooting learnphotography Pentax DSLR Discussion 7 04-10-2010 08:28 AM
High speed SDHC cards and K200D's continuous shooting. hahifuheho Pentax Camera and Field Accessories 4 04-02-2010 02:42 PM
All times are GMT -7. The time now is 08:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
