03-11-2010, 12:42 PM   #1
K7 image size shifts slightly
A curious thing I've noticed on my K7. When viewing stored images on the LCD, the image will begin at full size, and a split second after - the image pulls in slightly, appearing a little cropped after the initial first second it shows.
This happens with each image viewed. It's subtle for sure, but definite. I'm likely going to ask Pentax in Golden Co for advice. Something is a bit warbly? - Possibly the main board might need replacement, or am I jumping the gun? Is this pretty common or just my copy?
I have to dash out for a meeting, and will check in later.
Discuss amongst yourselves (in my best Mrs Richmond -Mike Myers/in-drag impression ;-p
Thanks,
Nic
03-11-2010, 12:55 PM   #2
mattdm's Avatar
Do you have the distortion correction feature turned on?
I haven't noticed this, but my suspicion is that it's initially showing the embedded thumbnail, which may not have that correction applied. Then, it re-displays with the full image (slower to load, so it doesn't do that initially), and you get full detail and the final corrected image.
Something like a physical connection problem seems extremely unlikely to produce this behavior -- it's not an analog TV screen, after all.
03-11-2010, 12:57 PM   #3
Same on my K.7, It is normal. But, the image begins as "croped", and then shows in full size. I guess that camera loads low resolution preview first for faster viewing, and after a moment it loads larger resolution image. No corrections turned on.
03-11-2010, 02:57 PM   #4
Yeah, I think it's not cropping, it's just taking a moment to load the shot at full resolution. Mine does this as well, as did my K-x, iirc.
03-11-2010, 03:24 PM   #5
My setting is off.
Hi Matt, thank you. No, In fact my settings are off. I tried it switched on, and it remains the same, no difference on or off. .......................Any other interesting ideas
QuoteOriginally posted by mattdm Quote
Do you have the distortion correction feature turned on?'''
03-11-2010, 03:26 PM   #6
As long as I'm on the same page, my image starts out full size momentarily, then pulls closer in, as if slightly cropping. That is opposite to what you are describing.
QuoteOriginally posted by Jadran Quote
03-11-2010, 03:37 PM   #7
QuoteOriginally posted by solar1 Quote
I've just checked - it starts full size when image is JPG, in RAW is the other way round. In first post I was refering to RAW images. But, anyway, it's obviously normal.
03-12-2010, 03:37 PM   #8
I just noticed the exact same thing on my K7. The preview displays, then after a sec it gets just a tiny bit larger. Not a big deal for me, but kinda odd.
03-12-2010, 05:15 PM   #9
It also happens on my K-x when I set the image size to jpeg 10M
camera, dslr, image, k7, photography, size
Image Size tcwilson Troubleshooting and Beginner Help 6 11-10-2010 07:29 PM
Image Size vs Document Size vs Resolution vs Resampling vs ... AHHHH! veezchick Digital Processing, Software, and Printing 13 08-02-2010 03:57 PM
Image size Jacos Troubleshooting and Beginner Help 15 04-11-2010 02:47 PM
JPEG Image Size hcc Troubleshooting and Beginner Help 21 04-10-2010 08:44 PM
1.53 vs. 1.54 (or even 1.57) and actual image size mattdm Pentax DSLR Discussion 0 05-23-2009 06:44 PM
All times are GMT -7. The time now is 11:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
