03-12-2010, 01:43 AM   #1
justinr's Avatar
Batteries
My K10 came with a battery rated at 7.4v and 1620mah. I have some spare batteries from another camera that are rated at 7.4v and 1500mah which are the exact same physical size and shape. Can I safely use these in the Pentax?
03-12-2010, 06:44 AM   #2
jots's Avatar
You just have to make sure that the + terminal and - terminal are in the same position as the K10's original battery. Then, as long as the battery will slide into the battery cavity, then you should be fine. 1620mah versus 1500mah are the capacity of the batteries.
03-12-2010, 08:38 AM   #3
justinr's Avatar
QuoteOriginally posted by jots Quote
Many thanks for the reassurance. I thought it would be OK but a second opinion is always welcome with me and electronics.
03-12-2010, 09:32 AM   #4
Ahab's Avatar
QuoteOriginally posted by justinr Quote
Of coarse.
03-12-2010, 01:36 PM   #5
Itai's Avatar
Batteries from the Konica-Minolta 7D and Dimage A2 fit and work perfectly on the K10D, if those are then ones you have.
- Itai
Digital Camera Buying Guide, Photography Articles and Reviews | NeoCamera.com
batteries, camera, dslr, photography
AA Batteries: What do you use? mnseawa Troubleshooting and Beginner Help 30 06-17-2010 07:09 AM
The best batteries chromo Pentax DSLR Discussion 7 02-14-2010 12:05 AM
AA Batteries for the K-X dmfw Pentax Camera and Field Accessories 12 01-22-2010 10:03 PM
best batteries?? strictlypentax Pentax Camera and Field Accessories 13 06-17-2009 07:21 AM
Off-Name Batteries pcfranchina Pentax DSLR Discussion 20 03-18-2008 11:22 PM
All times are GMT -7. The time now is 06:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
