Originally posted by Pentaxor anyway, I'm curious to see if there is really a noticeable significant difference between a 14bit and 16bit on any images presented (side by side).
You'd never get an apples to apples comparison (same camera with both ADCs).
This is highly dependent on the analog source and whether there actually is 16-bits of info in it (*after* accounting for noise in the signal paths), so once you change camera bodies, you're comparing apples to oranges. If there are 12-bits of info, it won't make a difference. If there are 14-bits of info, the 16-bit ADC might be more accurate (the 14-bit ADC will be spec'd w/ an accuracy rating over the last few bits of data)...
