07-10-2007, 04:50 AM   #1
Weird front wheel problem.
I just noticed something very strange with my k10d. Suddenly the front wheel was not working at all, in any mode where it was supposed to do something, it did notthing. I tried to reset the power first but that didnt do anything.
After trying a bit I realized that it was the grip that was causing the problem. if I turn off the on/off switch on the grip then the front wheel works, or of course remove the grip or the battery inside it, but just changing the power also works.
I suspect, and hope! that if I recharge the battery thats in the grip then the problem will go away.
very strange thing to happen anyway..... the camera is working fine except for the front wheel with the grip attatched btw.
07-10-2007, 07:08 AM   #2
I also had this problem a while ago. It turned out that one of the e-dials on the grip was turned and positioned just between the clicks on the dial. Just snap it into a click and it will work again..
07-10-2007, 09:40 AM   #3
and
Haha, hey! and welcome to the forum. thats funny did you join up just to help me out?
Yep you were right on the money! I turned the wheel on the grip and now all is back to normal. Hopefully others experiencing this can run into this thread and discover the root of the problem.
07-10-2007, 01:00 PM   #4
I think that this belongs in the Pentax Photography Knowledge Base.
battery, camera, dslr, front, front wheel, grip, photography, power, wheel
Weird problem with K10D RipDaJacker Pentax DSLR Discussion 9 08-07-2010 10:05 AM
weird KX problem tux Pentax DSLR Discussion 1 12-25-2009 05:42 PM
Weird Manual lens problem columbus Pentax SLR Lens Discussion 11 09-27-2009 02:00 PM
Weird double exposure problem pserko Pentax Medium Format 5 01-26-2009 07:13 PM
weird problem philmorley Pentax DSLR Discussion 5 08-31-2008 01:17 PM
All times are GMT -7. The time now is 11:45 AM. | See also: NikonForums.com, part of our network of photo forums!
