03-19-2010, 01:40 AM   #1
Using SR with TCs and/or extension tubes
When the Shake Reduction is turned is on and I'm using a teleconverter should I give the camera the focal length of the lens alone, or the focal length of the lens multiplied by the TC's magnification?
E.g. assume I'm using a 50mm lens mounted on a 1.7 TC. When I switch the camera on the SR system wants me to dial in the focal length of the length of the lens. Should that be 50mm, or 85mm (50*1.7), or something else?
Also, for the purposes of the SR what effect do extension tubes have? If I'm using the 50mm lens on a 31mm tube, should I tell the camera that it's a 50mm lens or an 80mm lens, or something else again?
03-19-2010, 02:50 AM   #2
RioRico's Avatar
QuoteOriginally posted by Spazmatazz Quote
Use the focal length of the lens multiplied by the TC's magnification.
I just looked at many discussions and calculations of this, but the rule of thumb WITH PRIMES is simple: add the extension to the focal length. In your example, tell SR it's 80mm. But my K20D will only accept 75 or 85, and your K200D is probably the same. So get as close as possible.
With zooms, it's a bit fuzzy. I *think* you add the extension to the focal length you're using, not to the minimum or maximum of the lens. I'm not sure if there's a difference using old push-pull manual zooms, and twist-to-extend zooms.
EDIT: My K20D manual says, "The Shake Reduction function may not perform as expected when shooting at close ranges." Gee, thanks.
03-19-2010, 06:56 AM   #3
Nice info and thanks for the warning.
03-19-2010, 07:11 AM   #4
Thanks, that's good to know.
50mm, camera, dslr, extension, length, lens, photography, sr, tubes
Extension Tubes for K7 Alex00 Pentax SLR Lens Discussion 6 05-31-2010 09:23 AM
For Sale - Sold: Pentax and Albinar 2x TCs, 2 Cokin A filter sets, 49mm Filter and Macro tubes pxpaulx Sold Items 15 02-11-2010 09:09 PM
Extension Tubes Charles1 Pentax SLR Lens Discussion 12 08-09-2009 05:20 PM
Extension tubes Charles1 Pentax SLR Lens Discussion 2 07-29-2009 02:22 PM
Extension Tubes kpfeifle Pentax Camera and Field Accessories 2 02-29-2008 12:24 PM
All times are GMT -7. The time now is 11:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
