Originally posted by sjwoo I've had the K-x for about a week now, and I experienced something very strange yesterday. I had the camera in M mode, and I'd set it down on the table after taking a few shots. After a minute or so, I looked at the camera, and the LCD screen had about 8 columns of various colors that ran vertically. I turned the camera off, and the LCD columns were still there! I turned it on and off again, and the columns disappeared and the camera was back to normal.
Earlier in the day, I'd upgraded the firmware from 1.00 to 1.01. But I can't imagine that would've caused that. Should I be worried?
Thirty minutes or so after changing from Eneloops to lithium. Left battery type set at NiMH by mistake. In and out of the car. Outdoor temp ~ 45F. No deliberate use of live view.
After shot or three, LCD seemed to fade, first image then exposure text. Red xfer LED was on. Bright multi-colored vertical bands appeared. Power switch did nothing. Then it shut down.
Removed batteries for 30 seconds or so, put them back in, booted fine. After another photo, same ugly thing. Took batteries out again, booted fine again. Light dawned, changed battery type to lithium. Powered down and waited a minute or so. Power switch turned to "on".
Camera was bricked.
Left camera at room temperature overnight with batteries out. Put lithium back in, nothing new. A brick.
Replaced lithium with Eneloops, fired right back up.
Warranty is ticking. Weather is warming. May not duplicate conditions for quite a while.
I'm tempted to ask Pentax to look at the camera, if only to preserve any rights to a recall or other remedial measures. I doubt they'd stand around in the Colorado Rockies for an hour or two to duplicate the temperature. Official spec is 32F so that should be fine.
Any ideas?
PS: Maybe they would replace the day-glo salmon color with a real red.
