Originally posted by fotopentax Its back in for repairs but the pentax clan at CR KENNEDY say its the quality of the battery thats the issue but was never an issue prior to the main pc board being replaced.
Post hoc, ergo propter hoc: because A happened before B, A caused B. Oldest logical fallacy in the book. I see no reason to even *suspect* that Pentax is wrong about this. Batteries go bad with time. Yours just happened to go bad within a month of when the camera was in the shop. And as the many threads on AA batteries should make clear, there are quite a number of AA cells that works very well with DSLR's - quite a few brnads of low-self-discharge "hybrid" NiMH cells, the new NiZn cells, Energizer Lithium, etc. These are no harder to obtain than the proprietary cells used by other cameras. Use whatever came you like, but assuming Pentax is bad because you had a problem using old batteries makes no sense,
