100% JPEG. Less than 0.01% of the time I also get the DNG (so JPEG+DNG) and end up discard the DNG nearly 100% of the time.
Get it right in the camera and there is no need to use anything but JPEG. Of course, I always use the highest quality and highest
resolution JPEG available. I always did that with all my cameras: K-7, K20D, K10D and my non-Pentax ones too.
With JPEG, the camera produces an image immediately. You can shoot DNG or RAW and you'll have to do the transformation yourself
later, on a computer, while you are not doing photography... Sure you can get a different result but only if you work at it. If you use
the default conversion and batch-convert everything you just got the same JPEG as the camera.
You want to see what is possible with JPEG only, straight out of the camera, without processing, cropping, straighting or anything
else? Check my gallery of Guatemela, it is entirely done with the K-7. Other than the 4 panoramas, everything is as-shot using a K-7:
http://www.neoluminance.com/query.php?gallery=Guatemala
- Itai
