03-22-2010, 12:15 AM   #1
Catch-in-focus with Sigma 500mm f4.5 & K-x
Does anyone know how to make this work? I have a manual lens which works OK but on the Sigma, switching to manual only affects the focus ring, it still auto-focussed unless the camera is switched to MF. Adding a TC does make it manual but the lens manual warns to switch the camera to MF to prevent damage to the camera motor.
03-22-2010, 12:28 AM   #2
RioRico's Avatar
The traditional way of finessing this is to put a dab of metal foil or tape on the bottom contact (closest to six o'clock). Shorting these contacts does no harm.
03-22-2010, 12:36 AM   #3
Do you short out 2 connections or one to the body of the camera?
03-22-2010, 09:43 AM   #4
RioRico's Avatar
QuoteOriginally posted by PMunks Quote
Just the one is all that's necessary. I'm fuzzy as to what all the connections do -- hopefully, someone with more expertise will jump in and inform us -- but apparently it's that last one that tells the camera if the lens is AF or not.
I've inadvertently shorted 3 or 4 contacts with aluminium foil between body and kit lens, and the camera couldn't get ID or focal length info -- SR asked me for the FL. Trap-focus worked anyway. I repositioned the foil to cover just the 6-o'clock contact, and trap-focus worked, with all other info automatically transferred.
Again, the shorting is non-destructive. I use a flanged adapter for some screwmount lenses, which adapter shorts out all the contacts, to no detriment. On M42 lenses with wide enough bases, I just put a strip of gummed metal tape on the lens base, then a non-flanged adapter, and several contacts are shorted. You can experiment with your Sigma, shorting one or more contacts, and see what happens. I may try that after I wake up. Gah, time to make some coffee...
camera, dslr, lens, mf, photography, sigma, sigma 500mm f4.5
For Sale - Sold: FA 50mm, Tamron 90mm, Sigma 150-500mm, Kenko 1.5x & 2x teleconverters (CAN) Doczi Sold Items 5 08-06-2010 08:24 AM
For Sale - Expired: Sigma 500mm F4.5 APO Manual Focus-K mount (Worldwide) kjames5 Sold Items 14 05-31-2010 03:34 PM
K7 & catch-in-focus... help! Nass Troubleshooting and Beginner Help 5 09-27-2009 12:36 PM
Sigma 150-500mm B&W Fl_Gulfer Post Your Photos! 9 01-26-2009 02:00 PM
All times are GMT -7. The time now is 12:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
