Originally posted by K7er Fabulous pictures!
I'm surmising the reason I didn't get things in focus was because there was a motion blur caused by the fast moving object or my own camera panning to track the objects (my shutter speed was only 1/250). Now, it makes me wonder what mode you guys shoot in? Is it Tv...Also, is SR on?
I don't shoot Pentax, but this really applies to any brand.
I would HIGHLY recommend shooting in manual Why? No meter no matter how good can properly handle the following scenarios well:
*) Dark bird small in the frame, bright sky (slightly overcast)
*) White bird nearly filling the frame
*) Dark bird nearly filling the frame
*) Bird flying against blue sky, next shot bird is in front of some dark trees
etc etc.. find me a rig that accurately meters in all those scenarios and I'll sell it to every bird photographer out there. Sure, you can fiddle with exposure compensation, but if you're shooting a dark (e.g. Cormorant) or light (e.g. tern) bird that's coming towards you the ratio of bird to background changes significantly and will throw that off as well.
So, make it easy on yourself and shoot manual. Exception being if the light changes a lot, in which case Av mode *might* be preferable.
Set the shutter to at least 1/1000. Turn off SR. Keep the lens wide open unless performance is a lot worse there in which case you need to stop it down a bit. Set ISO manually, ensuring you can get enough shutter speed. Snap off some test shots, chimp the histogram to make sure you're not clipping (if shooting JPEG) or clipping too much (if shooting RAW).
Go shoot, adjusting shutter/ISO as needed when the light changes.
That's my $.02...
