Originally posted by jaitas If it helps somebody I can confirm that Eye-Fi Explorer X2 works great with K-7... Endless memory mode is quite nice
I'm going to try the X2 Pro on the K2000 as soon as my lens arrives. I've been using it on my Lumix FZ28 and was planning on getting one of the cheaper X2 cards to go into the K2000 (once you go eye-fi it's hard going back
I'm guessing though that if the k-7 is supported as listed, then it would support the .pef raw files, so it should be fine. The only issue as someone mentioned above would be the power required. These cards transfer your pics as long as your camera is on, once you turn it off, it won't be able to transfer till the next powerup (but it resumes). Also, for geopositioning you should wait before turning it off so it can grab all the wifi mac addresses around.
