Originally posted by Jon in SC K7
Weight: 750 grams
Deminsions: 131x97x73mm
Kx
580 grams
deminsions: 123x92x68mm
That K-x weight is rather misleading, as it is with disposable (aka single-use / non-rechargeable) lithium batteries. Use NiMH rechargeables (which weigh significantly more), and the weight difference is quite a lot less.
Originally posted by flippedgazelle Then perhaps there is an alignment issue with your K-x, if your comparison is being made with the same lens. The K7 and K-x share the same 11 point AF system.
They're not the same, they're *similar*. The K-7 accounts for light wavelength when determining focus (courtesy of an extra sensor the K-x lacks); the K-x doesn't account for this. The K-7 also includes a built-in AF assist lamp, and the K-x doesn't. The K-7 also allows AF fine tuning of lenses and the camera body; AFAICR the K-x doesn't.
