Originally posted by Rondec I am just going to repeat what I said before. As far as I can tell, if you use Save As when converting RAW to Jpeg in Photoshop Elements 7, the metadata should remain intact. All of my lenses show up under Camera info when I look in Elements 7. I understand that a couple of the most recent lenses (DA*55 and 60-250 wouldn't), but the lenses I own are read by the software.
Sorry to contradict - I'll also repeat that I did Save As using Elements 7.0 (and I am experienced at doing this) I don't know why but I do
NOT retain the lens info.
I definitely see the lens info when I open the original out of the camera unedited file in Elements 7.0 -
and after doing a Save As - most of the EXIF is there including camera, exposure info, focal length etc -
but I cannot find the lens info even using PhotoME search on "lens".
Here are two examples I shot a paired RAW/DNG+JPG opened them both in Elements 7.0 just now - I can definitely see the lens info in Elements 7.0 on both.
All I then did was to resize the photos and added the text to identify them - then Save As JPGs -
as can be seen from the filenames they have "copy" in them which is the Elements default naming convention I just added the JPG and DNG in the names to distinguish them.
No other editing, and I did not edit the EXIF metadata - they are literally as-is from my copy of Elements 7.0
The RAW/DNG converted version:
JPG version:
both still have EXIF still attached (caveat - PhotoBucket can sometimes mysteriously drop metadata) -
please open them in PhotoME and do a search on "lens" -
as I said I cannot see the lens info.
What gives?
