04-25-2010, 05:08 AM   #31
audiobomber's Avatar
QuoteOriginally posted by bazzie Quote
What is the point of having almost infinite JPEG presets, as we do with the K-x, when you then disregard them by fiddling with the RAW image?
If you use DCR4 for jpeg conversion, then your presets matter. The raw image is displayed with your camera settings, although they area not applied until you extract the jpeg.
04-25-2010, 05:33 AM   #32
when i have plenty of light i shoot at iso 125, i found it a little less noiser than iso 200 but i don't have to underexpose to get rid of the higlight clipping at iso 100 (dunno if has less DR or you only need to underexpose by 1/2-2/3 stop).
Sice i shoot raw i use iso 12800 when needed (and do noise reduction in PP) even if the loss of fine detail between 6400 and 12800 it's quite evident when pixelpeeping but i've to print a couple of 10x15 to see if there are real difference.
If i was using jpg i don't know if i would use iso 12800, i found that with the built-in camera NR the fine detail are washed out.
04-25-2010, 02:19 PM   #33
twitch's Avatar
Mine is set on 200-3200. I've gone back and forth between 200-1600 and 200-3200. I've found so long as I don't under expose, 3200 is OK.
camera, dslr, iso, k-x, photography
K-x Iso settings EliBurakian Pentax DSLR Discussion 2 11-11-2009 09:24 AM
ISO Settings Garyleed Troubleshooting and Beginner Help 6 09-15-2009 09:01 PM
ISO Settings Help photapioca Troubleshooting and Beginner Help 18 05-01-2009 10:57 AM
ISO Settings Fl_Gulfer Pentax Film SLR Discussion 13 08-05-2008 11:50 AM
High ISO settings and the K10D/K100D krs Pentax DSLR Discussion 6 02-28-2008 07:38 PM
All times are GMT -7. The time now is 07:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
