Originally posted by Unsinkable II A backlit sensor would seem to inherently have more reserves, so going with Sony's Exmor would look like the better bet...
If you're talking backside illuminated, that's
Exmor R, not
Exmor.
Backside illuminated sensors are not a relevant technology for DSLRs. Their positives are outweighed by their negatives at APS-C size. For one thing, they're more expensive to make due to lower yields, and more fragile because the wafer must be thinner.
More importantly though, they provide very little benefit at DSLR scale. All they're doing is moving the circuitry from the light sensitive side of the chip to the reverse side, which leaves a little more space for light gathering on the active side. Thing is, that can bring a significant gain in a small, high-resolution, high pixel density compact camera chip, because there the wiring takes up a significant portion of the surface area. For a large APS-C chip, though, the wiring isn't proportionally greater in area for each pixel than in the compact camera chip. The wiring covers a much, much lower percentage of an APS-C chip's active surface, meaning that the total saving to be made with an APS-C BSI chip is much, much less.
Simply put, at APS-C scale, the disadvantages in cost and fragility far outweigh the very slight performance gain on offer, at least with current pixel densities. (If we get up to resolutions nearer 100 megapixels on APS-C (please God, no!) then BSI might be applicable on such large chips.
Originally posted by Rondec Is there an Exmor that has the same pixel count as the K7 and similar video capabilities? I am not being sarcastic, just wondering. I hardly see Pentax putting a sensor in the K7 sequel that can't do 1080 HD video at 30 fps. Not that video is that important to me personally, but it seems that it is the big thing selling cameras right now (look at the T2i).
A more important issue is that Exmor R chips aren't available in APS-C size, for the reasons stated above. ;-)
