You're talking about the "auto iso setting" in the first menu page?
Well, when you press the "right" button (left one is WB), you go in the auto iso setting.
Ok that far? Press right again and you'll be able to choose your lowest and highest iso.
My settings are 100-800 (and auto iso setting on slow). If I want to go above, I have to push the ISO button and then I can go above 800 ISO.
Since you have 200 on lowest, you can only go below 200 if pushing the ISO button.
Is that right? Or did I misunderstood?
I don't know about highlight correction since I don't use it. But you can give the auto iso settings a try. Change 200 to 100 to start with
And another thread says Dynamic Range Ex. is the solution.
Good luck and tell us if it worked.
