Originally posted by Jacos I am almost ready to purchase a K-x after finding some videos showing that the cross processing effect can be used when recording movies.
I cant find any videos showing the 'minature' filter being used. Is it possible to use this filter when recording movies so that it has a tilt shift effect like the 'diorama' filter on the Epl-1.
Many thanks.
Been a while since I used the K-x, and I can't remember if it has that capability or not.
I definitely WOULDN'T use its presence on the E-PL1 as a buying point though - it's so limited that it's effectively a non-feature. The PL1's Diorama filter takes so much processing power that even for still images, the live view framerate plunges to somewhere around two frames per second. The same is true in movie mode, but Diorama movies still play at 30fps -- so they play back at about 15x normal speed. A further limitation is related to the accelerated playback - audio is completely disabled when recording Diorama movies, and cannot be re-enabled.
To be honest, you're far, FAR better advised to just add the tilt/shift effect in software afterwards, rather than using the PL1's Diorama filter when recording a movie.
