04-04-2010, 06:28 AM   #16
mickeyobe's Avatar
How sturdy is your tripod?
Was there a breeze?
Does the floor have even the slightest give as so many modern structures do?
What is a FAT tree?
One last try. One step at a time.
Set the focal length to 18mm.
Open your aperture to f3.5. (That is as wide as it will go.) O
Set the focus ring to infinity (∞).
Take a picture being certain that nothing moves the camera.
Now set your aperture to f8 (that is a smaller aperture than f3.5.) o
Make sure the focus ring is still at infinity (∞).
Next set your aperture to f22 - The smallest aperture on your lens.
Take a picture being certain that nothing moves the camera.[/U]
To carry your test even further -----
Repeat the above steps exactly with the focal length set at 35mm and the again at 55mm.
You will find that as you increase the focal length the maximum aperture will decrease (get smaller) to f4.5 and to f5.6. That is the nature of most lenses. It will cause the exposure times to increase in order to maintain the correct exposure.
One other thing. Do not focus by looking through the viewfinder. Just set the ring at ∞ and forget about what the viewfinder shows.
Good luck.
Mickey
04-04-2010, 06:53 AM   #17
here it is
full size zipped.
exif all inside.
http://www.4shared.com/file/25665442...70f/photo.html
on tripod
is off
timer 2sec
f3.5, f6.3, f13
iso 200
Manual focus (resulting in infinity focus) using live view 10x magnification.
How i do? i select widest aperture which is f3.5, use live view 10x to focus at the jumping board. then shoot n change to f6.3 and then f13.
Focus at the jumping board of the swimming pool(center of the pic)
the whole content of the photos are far enough to be in the hyperfocal zone of my kit lens at 18mm. so any F-stop produce almost no difference. juuuuuust a bit blur in the f13, could be diffraction like labert'd said. i tired RAW and same result.
04-04-2010, 07:03 AM   #18
Photos look normal to me.
04-04-2010, 12:17 PM   #19
mickeyobe's Avatar
learnphotography,
Could you please send your photos the normal way so that I can see them.
Mickey
04-04-2010, 04:59 PM   #20
tokyoso's Avatar
QuoteOriginally posted by learnphotography Quote
here it is
on tripod
is off
timer 2sec
f3.5, f6.3, f13
iso 200
Manual focus (resulting in infinity focus) using live view 10x magnification..
you might get better technical support from pentax customer service. send them the files and have them troubleshoot your gear. it sounds like you're still under warranty...
04-04-2010, 11:32 PM   #21
twitch's Avatar
Is there a cheap UV filter involved here? Photos seem very blurry.
buildings, camera, dslr, f3.5, f5.6, photography
Vivitar 85-205mm 2.8/f aperture not working Minoltaguy Pentax SLR Lens Discussion 0 03-29-2010 09:33 PM
K20D Problem: Manual and Menu not working anamnezis Pentax DSLR Discussion 5 01-05-2010 02:48 PM
K200d and weird non working aperture. zelovoc Pentax DSLR Discussion 3 12-13-2009 02:38 AM
aperture problem with 50 1.7 kent Pentax SLR Lens Discussion 9 11-01-2009 05:11 AM
SEARS 80-200mm aperture not working michalko99 Pentax SLR Lens Discussion 1 08-24-2009 09:44 AM
All times are GMT -7. The time now is 08:15 PM. | See also: NikonForums.com, part of our network of photo forums!
