04-02-2010, 09:42 PM   #1
I'm having a funny problem with aperture. It's not working as it shold be
I'm using pentax kx 18-55mm kit lens.
I read that high f-stop gives good focus on far n near object. And i see on the net people use f9 and above when shooting buildings, landscapes and far objects.
So i tried experimenting on my own.
but the sharpest image i get is when i use f5.6. not f3.5 nor f9+.
F9+ is making the buildings n trees blur. And i also don't how come F5.6 is sharper than f3.5.
Av Mode 17mm:
Cropped
f3.5
f5.6
f9
04-02-2010, 10:00 PM   #2
Many lenses are not "sharp" wide open, especially kit zooms. Stopped down one or two stops (f5.6) generally improves that dramatically (on some lenses more than others). At f9+ your shutter speed may be too slow to get a good shot. If you really want to experiment with it, get 3 like objects (like AA batteries, I know you have some of those) and line them up about a foot or so apart on a table. Focus on the middle one from various distances and at various apertures. You will discover 2 things. First, the closer you are to the objects especially wide open, the more blurred the outer objects will be. Second, the further away you are, the more in focus they will be, even at the same apertures.
Without worrying too much about the physics of it, You've just learned the useful application of Depth Of Field (DOF).
Now take it one step further and adjust your ISO so you can get a faster shutter speed if need be. The Antishake is a nice tool but that's all it is, and it's a fallible one at that.
04-02-2010, 10:06 PM   #3
The lower the aperture (larger f-stop number), the slower the shutter is at the same exposure. It is possible that f/9 is causing the shutter to be slow enough that either camera shake or a light breeze disturbing the foliage is causing things to be less "sharp".
Could you post the EXIF for your images?
04-02-2010, 10:11 PM   #4
See here: https://www.pentaxforums.com/forums/photography-articles/62522-exposure-shutt...rture-iso.html
Keep in mind that the higher aperture will require a slower shutter speed, so your images might have been subjected to added shaking/motion blur.
04-02-2010, 10:56 PM   #5
lens resolution and focus are different things also...
all lenses have an optimal f stop where they get the best resolution, this is also a factor at play here.
04-02-2010, 11:20 PM   #6
From looking at your pictures I would conclude that you focused on the foreground.
For landscapes you might try setting your lens on manual and set the distance on infinity "∞".
I think everything in your photo is far enough away to be considered at infinity - even the foreground palm trees.
It also appears that you may not be hold your camera steadily enough. Keep your arms down at your sides.
Mickey
04-02-2010, 11:35 PM   #7
Hi guys, thanks for all yr help
here are 3 more shot
I used a tripod
IS off
AE spot & AF spot
Focus on the white honda civic.
what I see is now the f3.5 is the sharpest among all.
I already know low f-stop give bokeh while high f-stop bring everything in focus.
now i learned that low f-stop also give better sharpness than high f-stop despite high f-stop bring backgrd n foregrd in focus.
for these shot, the car is very far away.. And, i have no close foregrd object so i think no need to use high f-stop. its impossible to make bokeh on the car unless i use super zoom lens. tt's why using low f-stop that bring best sharpness is the best for distant object.
must correct me if i m wrong!! please
cheers
f10
F5.6
F3.5
04-03-2010, 09:19 AM   #8
Maybe my eyes are not so good but to me all 3 pictures are not sharp. The picture taken at f3.5 has higher contrast but the sharpness is not better than the other two.
04-03-2010, 09:28 AM   #9
Marc Sabatella's Avatar
Your basic problem is a basic misunderstanding of the topic of Depth of Field, so I'd suggest googling that term to get a better understanding of how aperture actually affects focus. it has nothing to do with how sharp the in--focus areas are, but with how *much* is in focus, and that is also affected by *where* you are focusing.
In the case of the car samples, nothing looks particular sharp to me, but I'd say you are seeing the effects of slight difference in focus and perhaps some camera shake (did you use the two-second timer on the tripod? how sturdy of a tripod?). because no way if f/3.5 going to be sharper than f/5.6 on that lens.
04-03-2010, 10:30 AM   #10
suggest turn off autofocus; focus manually at widest aperture (lowest f/#), then stop down to take photo.
04-03-2010, 10:34 AM   #11
None of the three pictures is truly sharp.
Regarding f stops. Think of them as fractions.
eg 1/3.5, 1/5.6, 1/10. Therefore, 1/3.5 is larger then 1/5.6 which is larger than 1/10.
You spot focused on the white Honda Civic. Depending upon where you put the spot, that car is almost featureless and lacks adjacent contrasting areas which autofocus needs to obtain its focus.
Why don't you try manual focus and set the lens at infinity as I suggested earlier and see what happens?
Focus with the lens at its maximum aperture which I presume is f3.5 and gradually stop down to minimum aperture (f10 ?) being sure not to alter the focus.
I think you are causing yourself needless aggravation. You have a good camera and a good lens and they will perform to your expectations when properly understood and correctly used.
Now let's see your next batch of photos taken in cooperation with your equipment. Forget about bokeh.
Mickey
04-03-2010, 06:45 PM   #12
tokyoso's Avatar
QuoteOriginally posted by learnphotography Quote
Av Mode 17mm:
Cropped
f3.5
f5.6
f9
i think like mickeyobe said flip your camera to MF and turn the focus ring all the way to infinity. set the camera on a table or lay on the ground outdoors when it's sunny. point it to somewhere far like you did there. set to Av mode , 2 sec timer and press the shutter.
try this with different focal lengths and fstops... etc. sounds like fun..
04-03-2010, 08:17 PM   #13
Hello thanks for all the comments,
here are another experiment as suggested my mickeyobe
AV mode
infinity focus at widest aperture (check with live view at 10x and the FAT tree is focused at infinity)
On a tripod
IS turned off
2 sec timer
mirror locked up
f13
f5.6
f3.5
I cannot see any noticeable difference. Only that the f3.5 sample shows a tad more contrast.
I'm focusing the fat tree in my lens hyperfocal zone i guess.
04-03-2010, 09:00 PM   #14
tokyoso's Avatar
i see that the exif data is stripped, but try focusing on the FAT building instead. my k-x kit has always focused to infinity with the focus ring all the way turned, AF or MF... but some lenses may vary.
04-04-2010, 06:19 AM   #15
Banned
Since you have the K-x that has Live View, you may want to use that for focusing - use the info button to zoom in and adjust focus (you can move the zoomed in area around with the arrows).
Ignore the trees, whose foliage might move, and focus on the building.
buildings, camera, dslr, f3.5, f5.6, photography
Vivitar 85-205mm 2.8/f aperture not working Minoltaguy Pentax SLR Lens Discussion 0 03-29-2010 09:33 PM
K20D Problem: Manual and Menu not working anamnezis Pentax DSLR Discussion 5 01-05-2010 02:48 PM
K200d and weird non working aperture. zelovoc Pentax DSLR Discussion 3 12-13-2009 02:38 AM
aperture problem with 50 1.7 kent Pentax SLR Lens Discussion 9 11-01-2009 05:11 AM
SEARS 80-200mm aperture not working michalko99 Pentax SLR Lens Discussion 1 08-24-2009 09:44 AM
All times are GMT -7. The time now is 09:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
