View Poll Results: How do you copy/transfer files to the computer?
Remove memory card from camera, insert memory card to computer's card reader 13880.70%
Connect the camera to the computer using the USB cable 3319.30%
Voters: 171. You may not vote on this poll
04-05-2010, 01:05 AM   #1
How do you copy/transfer files to computer?
How do you copy/transfer files from your camera to the computer?
Do you remove the memory card from the camera then insert it to the computer's card reader?
Or do you use the USB cable to connect the camera to the computer?
04-05-2010, 01:10 AM   #2
Pablom's Avatar
I use card reader. it's more comfortable and I think faster too
04-05-2010, 01:13 AM   #3
starbase218's Avatar
Location: Planet Earth, Sol system, Milky Way galaxy, Universe
I voted the cardreader option, but when I'm traveling, hotel computers often only have USB ports, so I use the cable when necessary.
04-05-2010, 01:27 AM   #4
creampuff's Avatar
Using the USB cable means keeping the camera on, which uses up batteries and prevents you from using the camera to shoot. Secondly, transfer by a card reader is noticeably faster. I also don't like to connect the USB cable as the physical connection to the camera is kinda flimsy imo plus one has to be careful not to eject from the computer side prematurely or risk corrupting any image files while downloading. A card reader is so much smaller compared to the USB cable size wise, a consideration when packing. Using an external card reader means having the camera ready to use by inserting a fresh SD card while images from the other card is being downloaded.
04-05-2010, 01:36 AM   #5
Kingston USB card reader for me most of the time - quick and easy. If i'm on the go, I have an SDHC slot on my thinkpad
04-05-2010, 01:46 AM   #6
hcc
hcc's Avatar
First my answer to the poll: I do use both a card reader and the USB cable, depending upon which computer I use. At home I use the card reader, but I use the USB cable when I travels or am at work.
Second, you were provided already with some good feedback: (a) the transfer rate with a card reader is faster indeed, and (b) you do not to switch on the camera.
But there is nothing wrong with a file transfer by USB cable: I have done it for 9 years with all my cameras without a single problem.
I add that I tend to empty my card as soon as possible for safety and backup, as well as for having a maximum storage space on the card at any one time. In addition, I tend to reformat the card every so often: (a) everytime there is a firmware update off course, and (b) every 2-3 months to check the card integrity.
Hope that the comment will help, although I could not contribute to the poll since there is no option for people using both card reader and USB cable.
04-05-2010, 01:55 AM   #7
sterretje's Avatar
USB only. Cable is far easier in my opinion. Disavantage, specially on AA powered models, is that it will drain battery power faster leaving less shots. Solution for that is obvious an external power supply.
04-05-2010, 01:59 AM   #8
I have a little SanDisk MicroMate. It's fast enough for me.
04-05-2010, 05:02 AM   #9
On board laptop card reader
04-05-2010, 06:09 AM   #10
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
$9.99 Targus card reader, which also reads just about any other card. Fast enough for me and I don't drain my camera batteries.
04-05-2010, 06:50 AM   #11
I think the biggest risk of using a card reader is that you sometimes forget to return the card to your camera afterwards. It's extremely disappointing to find that you've lugged you camera and heavy lenses around and you can't take any photos because of a lack of memory.
04-05-2010, 07:58 AM   #12
In my PC at home if I use the USB, I am not able to tranfer the Raw files. While if I use the card reader I am able. I have no time now to see what is the problem, so i continue to use the card reader.
04-05-2010, 08:42 AM   #13
Marc Sabatella's Avatar
QuoteOriginally posted by hangu Quote
Having a spare card in the bag would prevent that from being an issue. Also, leaving the card door open while downloading, so you'll notice it next time you go to use the camera, helps prevent it happening in the first place. I always put the card back in the camera immediately after downloading; it's just part of my routine.
04-05-2010, 09:20 AM   #14
I do the same as Marc. I leave the door open so I know that the card isn't in the camera and as soon as the photos are moved to the computer, I put the card back in the camera. And I also have more than one card.
04-05-2010, 09:37 AM   #15
mickeyobe's Avatar
I always use the USB cord.
Along with an exterior power supply (AC Adaptor) that I purchased with my K100d.
Transferring to my iMac which, fortunately for me is foolproof, fast and imposes no drain on the batteries.
I also use the power supply when I clean the sensor.
Mickey
camera, card, computer, dslr, files, photography
Photos transfer to PC Frankie500 Photographic Technique 2 09-08-2009 02:46 AM
transfer warranties? FHPhotographer Troubleshooting and Beginner Help 1 03-09-2009 07:39 PM
Computer power and 14mp files... Ratmagiclady Digital Processing, Software, and Printing 21 12-17-2008 01:17 PM
File transfer jdg Photographic Technique 17 11-19-2008 10:03 PM
pc transfer sketchin13 Photographic Technique 0 05-31-2007 08:35 PM
All times are GMT -7. The time now is 09:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
