Originally posted by Anthony12 (snip) I love the camera but a little disappointed in the flash cycle. (snip)
Okay, how good are you at basic hand tools and soldering, Anthony? There is an easy way to dramatically shorten recycle times - build an external battery pack. Since photographers have been doing this for decades, it's not exactly a new idea. I've done this with several of my external flash units in the past. Anyway, this is an easy afternoon project, requiring only basic tools and a touch of soldering. Please read and re-read these entire instructions before proceeding.
The general idea is to use larger batteries in the external battery pack. Most AA-size batteries top out at about 3200mAh. However, C-size rechargeable batteries are commercially available in capacities up to 5500mAh, while some D-size rechargeable batteries are rated at over 12000mAh.
All standard sized batteries, AAA through D-size, are 1.2-volts. As such, voltage is not an issue here. What we're interested in is the capacity of the battery - how long it will hold a charge (rated in mAh). If one is interested in the longest battery life, the D-size batteries are the obvious choice. However, the C-size batteries are smaller and lighter in weight. Which one is entirely up to you (see below for more about rechargeable versus non-rechargeable).
Once you've made that choice, the next step is to purchase the parts for the external battery pack. Here is what you'll need...
- 1x C-size or D-size 4-battery holder (available at most electronics stores, such as Radio Shack)
- 4x rechargeable or non-rechargeable batteries (C-size or D-size, again your choice)(if you select rechargables, you may also want to pick up a charger at the same time)
- 1x round wooden dowel exactly the width of an AA-size battery (available at hardware store - take a battery with you to check size)
- 4x round-head wood screws
- 1x thin, small-guage, two lead, wire (length your preference - see below)(available at electronics stores, including Radio Shack)
- 1x case for battery holder (one of the small camera cases available at most stores is a good choice)
All of this, minus the batteries and charger, should cost less than $20. The cost of the batteries and charger varies greatly depending on brand, capacity, and so on. You'll also need some basic tools...
- 1x Screwdriver
- 1x soldering iron
- 1x very fine cut saw
- 1x drill (with bit properly sized for screw threads)
To build the battery pack, start by cutting the wooden dowels. You'll need four pieces exactly the length of an AA-size battery minus the positive contact protrusion. These will be the four fake batteries inserted into the flash in place of the real batteries.
The next step is to solder the wire to the battery holder. Many holders have wire leads already attached to prevent the soft plastic holder from being damaged by hot soldering. If you're good at soldering quickly, I recommend snipping these leads and soldering your wire directly to the holder. Otherwise, solder your wire to the existing leads and cover the bare wire with electrical tape.
Next, snip the other end of the wire to the preferred length. For example, if the case purchased is designed to clip to your belt, measure a length of wire from your waist to your eyes (allow an additional extra foot or so for play).
Now solder the other end of each wire lead to one of the two screws. So the screw will sit flush when screwed into the wooden dowel, it is important to keep this soldering as flush as possible with the underside of the screw head.
You're just about finished now. Drill a small hole centered into the end of your four fake batteries and attach the four screws. At this point, each of your four fake batteries, with the screw protrusions, should be roughly the overall length of a typical AA-size battery, including the positive contact protrusion.
One of your fake batteries will be the positive and the other the negative when inserted into the flash (the other two fake batteries have no electrical connections). Look at the battery holder to see which lead is the negative and which is the positive. Trace the leads to your fake batteries and mark each one with this information (+ and -).
Next, insert the fake batteries into the flash unit temporarily and look where the power cord can exit the flash unit's battery compartment. You'll need to drill a small hole along the edge (note "edge" here) of the battery door at this point to allow that power cord to exit. The wire from the fake batteries will ultimately be fed through this hole during use.
Finally, insert your batteries into the holder, your holder into the case, and fake batteries into the flash unit. You may want to wrap the wire once around the holder inside the case to act as a strain relief. Now, unless you inserted the fake batteries backwards, your flash should start up and function normally. The only difference is the flash should now operate much longer between battery charges, with much faster recycling times.
There is also one other issue to consider here. Voltage does impact flash recycling times. Rechargeable batteries are rated at 1.2-volts, while non-rechargeable batteries are rated at 1.5-volts. The flash will recycle quicker with that 1.5-volts. As such, if flash recycling times are important, you may want to consider non-rechargeable batteries. The C-size or D-size non-rechargeable batteries will provide power for many flashes (far more than AA-size batteries), so this is still a reasonably economical solution. Another option is to keep an eye out for the higher voltage (1.5 to 1.7-volt) rechargeable batteries just now being announced by several battery manufacturers (coming soon, but not available yet).
That's it. Enjoy your new battery pack and improved flash performance.
stewart
Copyright ©2007, Stewart, Stewart Photography. All Rights Reserved.
