Originally posted by Ash Hello and welcome here.
Your flashes will work, but unfortunately not in TTL mode.
A and M modes should be fine though, and it may need some mastery on your part to make them work well for you.
Originally posted by theperception2008 As Ash said they will work fine, but either in A or M mode. I just bought a af280t for my K100D Super as I like the functionality without the extra costs :-P. Also it will work fine with my Pentax Super Program too!
Hi pz1,
I'm afraid the above posts are only partially correct. I have a 500 FTZ, which does not have an A mode, and from B Dimitrov's site, the 330 does not have this mode either.
Auto Focus Pentax Flashes
Your flash guns will work, but in M mode only. TTL requires a separate dedicated sensor in the camera which the Kx does not have. Only the *ist D, DS, and DS2 have had them in the DSLR series. BTW, manual flash is not that big a deal with digital, it's pretty easy to dial it in with a few test shots. With film, unless you had a darkroom in your pocket, this was not practical.
Scott
Reason: added some text
