04-10-2010, 01:29 PM   #16
Ash
Community Manager
Ash's Avatar
And tungsten light can contribute to metering difficulties also.
Ultimately, the idea of digital photography is that results can be reviewed on screen and the shot retaken if required with the necessary adjustments.
04-10-2010, 01:42 PM   #17
drougge's Avatar
QuoteOriginally posted by philbaum Quote
c. When in Pentax's AV mode, i've found that its too easy for the camera to switch between manual iso settings and Auto ISO settings in that mode. I think what i'm doing is punching the green button and that enters the AV manual ISO mode into Auto ISO mode. to get it back one has to go into the Fn menu.
No you don't. You can set the ISO with the front wheel while holding the OK button (in any mode that will let you set the ISO). You could also set one wheel to always be ISO in Av mode, if you don't use it for compensation. (I can't imagine why Pentax felt that one wheel should do nothing by default in Av mode, but at least it's easy to change.)
av, av mode, camera, dslr, iso, k10, mode, photography, pictures, settings, shutter
Question: K10/20 and remote AF360/540 in manual mode? Ivan Glisin Flashes, Lighting, and Studio 4 01-22-2009 03:26 PM
K10 Raw Capture in User Mode josh Pentax DSLR Discussion 3 02-08-2008 03:40 PM
k10 problem! bebop Pentax DSLR Discussion 2 09-25-2007 10:27 PM
Pentax K10 Problem paulrad Pentax DSLR Discussion 12 07-07-2007 10:43 AM
Another K10 problem :( slip Pentax DSLR Discussion 14 01-25-2007 02:51 PM
All times are GMT -7. The time now is 10:27 AM. | See also: NikonForums.com, part of our network of photo forums!
