04-09-2010, 08:12 PM   #1
My SD card cannot keep up to speed for Pentax K-X HI Continuous shooting
I have got a class 4 4gb but the Hi speed continuous shooting is lagging. i do not experience this for HD video recording.
I can only shoot 2 to 3 jpeg and then it stops and the red light appear indicating it is writing jpeg into the memory card.
what is the cheapest possible sd card class that can handle the k-x hi continous shooting mode in RAW, JPEG and RAW+ JPEG?
04-09-2010, 08:24 PM   #2
Wheatfield's Avatar
First, make sure you have the lens correction functions turned off, as that slows things down.
I've always used the fastest Sandisk cards that I can buy. This doesn't translate to cheapest, but I find them reliable, which means more to me than a few dollars.
04-09-2010, 11:43 PM   #3
hcc
hcc's Avatar
QuoteOriginally posted by learnphotography Quote
Wheatfield is correct: do switch off ALL post-processing including lens distortion correction.
This might not be all. The K-x has a small buffer and it will become full very quickly, unless you have fast card and set the file sizes at 6 Mp or below. As soon as the camera buffer memory is full (or near full), the Hi continuous shooting speed will slow down.
There were several relevant threads in Pentaxforums.com that you should read including:
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/95892-k-x-conti...oting-raw.html
https://www.pentaxforums.com/forums/pentax-dslr-discussion/93186-k7-high-spee...-shooting.html
https://www.pentaxforums.com/forums/pentax-dslr-discussion/90316-k-7-movie-st...0-seconds.html
https://www.pentaxforums.com/forums/pentax-dslr-discussion/87505-k-x-continuo...g-problem.html
I think that a class 4 card is not fast enough is your files are more than 2 Mp. If you intend to do a lot of Hi continuous shooting a class 10 card of good quality is necessary (or faster).
Hope that the comments will help.
04-09-2010, 11:49 PM   #4
jct us101's Avatar
I have a slightly dumb question, but sometimes the slightly dumb questions are the most difficult to find.
Is your camera set on continuous shooting or single shot?
04-09-2010, 11:53 PM   #5
Ivor K Ecks's Avatar
I have a class 4 sandisk 4Gb card and it will let me shoot contiuously for 22-24 frames at maximum quality and 12 megapixel, all post processing turned off.
04-10-2010, 01:51 AM   #6
Problem solved! i had distortion correction and Lat-chormatic-ab adj On. But those are some nice features. Does a fast card allow those two features to be on but not lag?
04-10-2010, 01:58 AM   #7
Pablom's Avatar
No.
the card is not the answer here. if it can make a difference you probably won't be able to notice.
04-10-2010, 08:28 AM   #8
hcc
hcc's Avatar
Pablom is right: the card will not make a difference. The lens distortion correction is an on-board processing feature, requiring CPU (processing time) from the camera itself, not the card. This is however not a problem as a nice small software PTLens (relatively cheap) can do the lens distortion corrections in batch for you later.
I have done a fair amount of testing with Hi continuous shooting with my K-7. I strongly recommend to switch off ALL processing for longer, Hi continuous shooting.
For example, I left the option "High ISO noise correction" ON once and I was shooting in the shade. The correction kicked in and the camera showed down after 10 s of shots (with the settings that I had then), much earlier than I expected!
camera, card, class, dslr, jpeg, k-x, pentax k-x, photography, sd, sd card
K-x Continuous Shooting Raw + DSLRnoob Troubleshooting and Beginner Help 12 04-03-2010 09:48 AM
High speed SDHC cards and K200D's continuous shooting. hahifuheho Pentax Camera and Field Accessories 4 04-02-2010 02:42 PM
K7 High Speed Continuous Shooting tpeace Pentax DSLR Discussion 18 03-15-2010 01:10 PM
Continuous shooting stalling ingi Pentax DSLR Discussion 10 05-29-2008 08:59 PM
k100 continuous shooting acrbill Pentax DSLR Discussion 10 02-19-2007 03:57 PM
All times are GMT -7. The time now is 11:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
