Originally posted by dlacouture Humm, JeffJs, sorry, but I cannot see where Borislav talked about AF.C or AF.S problems...
Borislav, your explanation seems clear to me, and I think your problem is that you are in Green mode... In this mode, a lot of things are set by default and cannot be changed!
For instance, the focus point selection is disabled (along with RAW shooting, etc).
Select any other mode (P, Av, anything), and it should work...
Yes, the AF C AF.S feature works perfectly.
But I did set it to AV and tried it on M. The switch just does not seem to do anything. I think I have a camera in which the switch itself is not working.
I could be wrong though. Is there any other option to turn this switch on? I tried the firmware update, and nothing.
