Originally posted by OrenMc Im thinking it is a SR issue. I have heard a few problems with the K7 and SR.
I can pull some crisp photos with the K10D at 300mm 1/30 sec.
Well, sure, it's never a matter of ironclads guarantees of success versus guarantees of failure - it's just a question of odds. Sure, *sometimes* SR will enable a sharp picture at 300mm and 1/30", but more often it won't. Your odds are *better* with 250mm at 1/200", but it's still no guarantee. So offhand, nothing about a few failures would seem to be indicative of any sort of problem at all. I think you need to do some controlled tests - same shot with same exposure settings, maybe 10-20 trials each with the K10D and K-7, and comparing results.
As it is though, the nature of the shots you are posting aren't very useful as tests. the subjects are moving, and assuming you are using AF, the scenes often have a confusing jumble of potential targets for the AF system. That introduces another random variable. A controlled tests means one in which the AF system has *nothing* else to focus on besides what you want.
