Originally posted by GerryL [snip] . . .
If the air inside that is trapped inside the camera makes it buoyant enough, then it would definitely stay afloat.
Look at the aircraft carriers made of heavy metal, they all float!
Depends on the density of the K20D
If the specific gravity (the ratio of density of the substance or object to the density of water, at a specified temperature, usu. 39 deg. F) of a K20D is less than 1000kg/m(3) then it will float.
For the Americans here, 1000kg/m(3) is about 64lb/ft(3).
I doubt it, but I use a battery grip, so maybe mine feels dense - but I'm not going to immerse a K20D to find its volume
