04-11-2010, 10:43 AM   #1
100 iso or Highlight Correction?
Hi Everyone.
While taking pictures the other day I wanted to slow my shutter speed by using 100 iso.
To do this I have to shut off Highlight Correction. I,m not clear on how this will affect my photos. Can anyone explain this to me in simple terms? Do most people use Highlight Correction? I have a k7 and shoot in raw.
Thanks
James
04-11-2010, 11:02 AM   #2
Ira
QuoteOriginally posted by jamescp Quote
Hi Everyone.
Thanks
James
If you're shooting raw, I think highlight correction is turned off by default. Not sure though.
04-11-2010, 02:32 PM   #3
jct us101's Avatar
By your question it sounds like you MUST turn it off to use ISO 100, but you don't NEED to, unless that was just your intention. It's just the base ISO of the camera, not sure if that's what you had meant though.
04-12-2010, 05:52 PM   #4
100 iso
Thanks everyone.
I think I'm beginning to understand this.
04-12-2010, 06:02 PM   #5
Ira
Highlight correction does not get high marks on the KX from certain reviews. Shadow correction is fine.
So you would have to have Expanded Sensitivity turned on, and Highlight Correction (HC) OFF to allow you 100, since HC on will automatically make 200 your minimum.
But in Raw, like I said, I think HC is turned off by default--but by NOT turning it off yourself as the default, you're still limiting yourself to a bottom of 200:
The camera doesn't apply your ISO settings to whether you're shooting raw or JPEG.
04-12-2010, 09:33 PM   #6
mysticcowboy's Avatar
Yes, highlight correction is turned off in raw. Are you sure that Extended Sensitivity needs to be turned on in the K7? The K-x, yes, but 100 is the base ISO for the K7.
michael mckee
My Port Townsend – A City in Photographs – 365
04-13-2010, 02:37 AM   #7
Ira
QuoteOriginally posted by mysticcowboy Quote
michael mckee
My Port Townsend A City in Photographs 365
Ooops. You're right. K7 for OP.
04-13-2010, 02:50 AM   #8
On the K7, highlight correction in RAW just underexposes the scene by one stop... So, it says 200 iso, but it is effectively exposing your scene using the 100 iso gain, then your Raw converter pulls up the exposure numerically (if aware of the Pentax HC feature)... That's why 100iso is disabled, as it cannot expose at 50 iso...
You'd be maybe better off by disabling this feature and controlling your exposure manually using Ev Comp in contrasty scenes.
camera, correction, dslr, iso, photography
Highlight / Shaddow correction bbullins Troubleshooting and Beginner Help 9 04-01-2010 12:15 PM
Default ISO 200 vs ISO 100 joodiespost Troubleshooting and Beginner Help 6 01-09-2010 05:50 PM
Highlight correction fulcrumx29 Pentax DSLR Discussion 2 08-16-2009 12:03 PM
K7 ISO 100 ?? how to kmanlaker Pentax DSLR Discussion 4 08-08-2009 09:18 AM
iso 100 or iso 200 kiwao Pentax DSLR Discussion 8 03-05-2009 01:02 PM
All times are GMT -7. The time now is 03:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
