04-12-2010, 02:35 PM   #1
axl's Avatar
K10D deteriorating focus - is it possible?
Some time ago I read about K10D's "changing" focus... is it possible?
To explain, when I got my FA43 in January, I had to set AF adjustment in debug mode to +190. Few weeks later I moved it to +200, around mid early/mid march it went to +220 and today (12/04) I had to set it to +240 to achieve perfect focus on f1.9. Is this possible or am I going crazy?
The camera has never been dropped, or treated badly. It's just about 18 months old with around 15,000 shutter count by now.
Any ideas???
BR
Peter
04-12-2010, 02:40 PM   #2
jct us101's Avatar
It might just be getting old, the AF motor has a bunch of parts that constantly are working, and I suppose that eventually they will just wear out. It seems like it takes a lot longer usually on any other camera but yours might have some kind of defect. You've never had any kind of problems with focus before now?
04-12-2010, 02:43 PM   #3
Tuner571's Avatar
Yea, I agree with jct on this one. As the camera ages finely tuned parts began to wear down and the camera becomes out of spec. I am guessing your going to have to send it to Pentax for repairs.
04-12-2010, 02:43 PM   #4
Lowell Goudge's Avatar
Somewhere I read there was a potential issue about the fact that the mirror had a single side rest, and that over time this cause the mirror (and its holding mechanism) to become distorted (tipped) causing loss of focus over time
search the forums, it was recientl;y
04-12-2010, 03:16 PM   #5
wlachan's Avatar
I read similar stories in other forums too in the past. 2 possible causes are 1) the mirror is moving out of alignment slowly (probably the rest arm), 2) the 3 screws holding the AF sensor underneath the mirror box are spring loaded and unscrewing themselves slowly due to insufficient threadlock. Perosnally, I believe #2 is more likely to happen to Pentax DSLRs. The AF motor module itself either works or not, it has nothing to do with AF accuracy.
04-12-2010, 04:03 PM   #6
creampuff's Avatar
This issue was posted earlier by frank. Basically the mirror on the K10D (and K20D) rests on one support pin in the mirror box. As the mirror flips up and down, the mirror will over time start to be off alignment as it comes to rest on one side. The AF sensor located at the bottom of the mirror box is fed light via the mirror, so any mirror misalignment will have an effect on AF accuracy. This issue was came to light quite awhile back. Those with high shutter count, and most K10Ds would fit the bill right now will likely encounter this issue over time. Cameras with this issue will find the AF accuracy to get progressively worse and while the AF module can be manually adjusted if sent for repair, this issue will persist so long as the mirror shifts ever so slightly. Only solution is to replace the mirror box assembly. Focus issues have been the bane for the K10D in the past and this issue will rear it's head again here.
BTW lots of 35mm SLR cameras in the past also had their mirrors resting on a single pin but with film cameras, they don't usually have such a high shutter count compared to their digital counterparts and the thickness of the film emulsion would probably mask some of the focus inaccuracies at the film plane. FYI the K-7's mirror rests on 2 supports, which probably will obviate this issue in the near future.
04-12-2010, 07:43 PM   #7
Unfortunately, it does seem to happen over time. My K10 gradually began to back focus. I guess the fortunate thing is that it seems to be a global issue, so using the debug mode on the camera seems to fix it over all. I guess you could send in it to Pentax, although in my experience, the cost of these repairs often is more than the camera is worth.
04-12-2010, 11:56 PM   #8
axl
axl's Avatar
Thanks for all the replies.
Lowell, I did try to search the forum but didn't come up with the thread I remember...
But the issue I remember was revolving around the one side supported mirror.
anyway, I'll be swapping my main body for my wife's K10D GP, that one is much younger with lower shutter count. So we'll see...
oh well, perhaps it's time to start saving up for K-7
04-13-2010, 07:26 AM   #9
Kenn100D's Avatar
Axl, your K10D's focus is already detioratiing. May i ask how many shutter count it has right now? Many thanks.
04-13-2010, 01:46 PM   #10
axl
axl's Avatar
QuoteOriginally posted by Kenn100D Quote
As I said, around 15,000 by now. Maybe bit more, because the pictures' numbering is at ~4500 sencond time now. Considering the manual WB, sensor cleaning procedures etc... maybe aroung 16000. I'll check tomorrow and we'll know for sure!
I did expect the camera to start failing but not after 15k pics only!
04-13-2010, 01:49 PM   #11
QuoteOriginally posted by axl Quote
that is my recollection also.
Note, and I do not believe this is related, but when I had my K10D shutter fail, pentax also replaced the mount and mirror assembly. Makes you wonder.
04-13-2010, 11:57 PM   #12
axl
axl's Avatar
It does indeed!
it's such a shame, because I love the camera. I really like the ISO100-200 output of the Sony CCD more than that of the Samsung 14mpx CMOS.
And other than this annoying focusing the camera is in great shape.
I may have to ask around if it would be worth having it serviced...
04-14-2010, 01:01 AM   #13
frank's Avatar
QuoteOriginally posted by creampuff Quote
Yes, I posted this during my version of K7 review last year:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/62819-experiences-...lots-imgs.html
Pity most of the photos were taken out due to lack of space in my free photobucket account, and I don't have them in hand right now.
Some K10D cameras have AF problem right out of box, some would have this problem along the way (and it gets worse). That's another reason you need to upgrade your K10D/K20D to a K7
04-14-2010, 01:04 AM   #14
In another thread, Lowell mentioned a cost of $325 (or so; canadian I assume) for the repair that he mentions in post #11.
Your call I think it's going to be a difficult one if that is indeed the cost.
04-14-2010, 04:21 AM   #15
axl
axl's Avatar
QuoteOriginally posted by sterretje Quote
hahahaha and that's really LOL
for that price? never!
I'd rather keep testing/readjusting as needed on weekly basis
Damn! I hope they'll bring new 2 dial camera out soon or I'll have to sell some stuff to get the K-7 with sensor I really don't like....
oh well, it's a beautiful life.....
camera, dslr, focus, photography
K10D focus issues Harald Pentax DSLR Discussion 26 02-09-2010 09:30 PM
Focus issues with K10D bethtphotos Photographic Technique 14 10-07-2009 05:57 PM
K10d focus hunting. Dale Pentax DSLR Discussion 5 04-29-2008 03:45 AM
So, I sent my K10D in to have the focus adjusted........ reknelb Pentax DSLR Discussion 8 03-15-2008 03:51 AM
k10d and auto focus The Pentax Hammer Pentax DSLR Discussion 3 07-10-2007 12:29 AM
All times are GMT -7. The time now is 11:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
