04-13-2010, 02:49 PM   #1
About the screws that hold the Pentax K-x together
Hi guys,
I broke the glass cover of the LCD in the back of my Pentax Kx.
Not a big deal fortunately: I ordered a new one from pentax for $4 + $0.6 for the double sticky tape and $8 shipping. Removing the broken glass was also not a big deal: just unscrew everything, lift a little bit the top (where the flash is) and remove the back cover.
The problem is... that I didn't realize all those little screws that hold everything together are in fact very different from each other. So, now putting things back is a pain in the neck.
Is anyone on this forum crazy enough to remove the screws from their Pentax Kx and tell me what goes where? Just removing the little screws w/o taking apart the camera is really easy peasy. Should not take longer than 10 minutes.
Thanks!
04-13-2010, 03:50 PM   #2
Ira
Where did you go to engineering school?
Test fit the screws before screwing the parts together, and make a diagram to know what goes where.
04-13-2010, 03:57 PM   #3
omega leader's Avatar
Harsh...however I don't remember that class when I took engineering. (only horrible diffEQ's).
Anyway, normally it isn't too much trouble to test fit screws. Try a small paperclip to determine the hole length if you have multiple of the same bore with different lengths.
Remember a tech has to be able to do this so it can't be too hard.
04-13-2010, 05:10 PM   #4
QuoteOriginally posted by omega leader Quote
Remember an engineer had to design it so to be as simple as it he could envision it so it is probably impossible!
04-13-2010, 05:13 PM   #5
jct us101's Avatar
Well you could probably find a diagram of the screws and the number in which they go in, but if you ever have to do this again I would really recommend that you get a little container and put each different type of screw in different compartments.
04-13-2010, 05:26 PM   #6
Tuner571's Avatar
QuoteOriginally posted by jct us101 Quote
Yea, this is what I do when I take small items apart. If I don't do that I usually group the screws with the piece that came off so I remember that way.
04-13-2010, 05:43 PM   #7
I didn't go to any engineering school.
It's quite difficult to test fits at this point. There are about 15 screws of 4-5 different kind. They are different enough to create trouble yet similar enough for me not to realized until I put things together.
04-13-2010, 05:45 PM   #8
jct us101's Avatar
Have you got it back together yet?
I would just suggest putting them all in different sets for the sizes and trying each one until you find one that works there.
04-13-2010, 06:00 PM   #9
Ex Finn.'s Avatar
"Remember a tech has to be able to do this so it can't be too hard.".
Thank god for engineers, for there is steady employment for technicians.
I mean... ever see an engineer fix anything?, ROTF FLMAO.
Anyhow, good advice about measuring hole depth.
Cheers, Mike.
04-13-2010, 07:19 PM   #10
I tried to match screws and holes so that they wouldn't be too tight or too loose and I think I figured some of them but obviously something is still wrong because I end up with two empty holes, two screws but not match :/
I asked technical assistance if they have a PDF version of the service manual to send me.
Note to self: never again take a camera apart if you are in a hurry.
04-13-2010, 07:28 PM   #11
GerryL's Avatar
QuoteOriginally posted by crocowhile Quote
Well, you got most of it right. Now it is just test fitting 4 screws..'coz you got 2 that don't match the holes and 2 that was already screwed in the wrong place that should actually be there.
Process of elimination. Just take it apart again and keep track of things.
04-15-2010, 03:27 PM   #12
Alright, it was more than 2 that I got wrong but eventually I made it. Thanks everybody.
04-15-2010, 03:44 PM   #13
GerryL's Avatar
Congratulations and it would have been great if you documented it the second time around for those who would want to take apart their K-x and replace something.
That would have been an invaluable info for the forums members.
04-15-2010, 05:32 PM   #14
Ira
QuoteOriginally posted by Ex Finn. Quote
Cheers, Mike.
Mike--you have no freaking idea. But I guess you do:
I'm in a work situation working with electrical and mechanical engineers (public agency), where if people knew what really went on, they would storm the building with pitchforks and torches.
04-16-2010, 12:45 PM   #15
QuoteOriginally posted by GerryL Quote
Yes, I will document the unmounting/mounting it when I will receive the glass from pentax.
camera, dslr, glass, kx, pentax, pentax k-x, photography, screws
Repair parts for lenses? (screws) ismaelg Pentax SLR Lens Discussion 8 02-13-2010 01:55 PM
m28mm/2.8 threaded mount mounting screws? John Araki Pentax SLR Lens Discussion 5 12-17-2009 04:36 PM
So, I just got a hold of a Pentax SLR... heavensSinner Troubleshooting and Beginner Help 17 03-07-2009 05:56 AM
Ok, how to remove screws from a Pentax-M lens?!? Isaac314 Pentax SLR Lens Discussion 0 10-24-2008 07:38 AM
Pentax Gallery "On Hold" tag wmmk Photographic Technique 9 04-20-2007 03:32 PM
All times are GMT -7. The time now is 10:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
