Originally posted by sterretje Marc, you're right. I never really played with it, but I think the one thing one can not do here is over/under expose. Must try it one day.
In TAv mode, you, the photog determines shutter/aperture while the camera determines the proper exposure by only changing the ISO setting - and this is NOT manual mode since the exposure is determined by the camera.
Originally posted by Workingdog Andy,
I know your problem as I noticed the same thing when I first bought my K10D. I had even selected high speed in the program line expecting that the camera would actively change the ISO to give a high shutter speed, but nooooooooo it didn't. Evidently the firmware is set up to give maybe 1-2 stops of shutter speed in high speed program line and to preserve a lower ISO setting as it's priority.
I noticed that the K7 allows the user to choose how actively the camera changes ISO. There are three settings; slow, normal, and fast. I suspect this was in response to your issue and mine.
Since exposure is comprised of three basic settings shutter/aperture/ISO, when you set program line to speed, the camera will adjust the exposure value based on your preference of keeping high speed as the priority. So, if there are several exposure values the camera can use, it will choose the highest possible shutter speed.
