04-15-2010, 02:11 PM   #1
K100D Firmware
So, my Mom bought a refurbished K100D off of Best Buy, and it looks great and was sold for a fantastic price. The only issue, is the firmware.
I downloaded the 1.02 firmware and used an old 16mb card to attempt to install the card for the install. When I turned on the power while holding the menu button down, the screen flashed the 1.00 firmware, but didn't start loading the new firmware, it just started up as normal. I've done two of these updates before and never had any issues. Does any one have any suggestions?
I had fresh rechargeables in? Would new lithium's make a difference?
Thanks!!!
04-15-2010, 03:40 PM   #2
GerryL's Avatar
Go to it step by step.
You might be going at it automatically in your mind and might have missed something.
Read the readme.txt file thoroughly.
If you do everything as the readme.txt file said and still nothing, then you might want to try another memory card since the card may be bad 'coz it seems like the camera isn't reading it by not recognizing the update that is in its root directory.
Batteries would only matter if the camera recognized the firmware update, and you should have a fully charged battery for it not to die in the middle of the update.
From your description, it would seem that the camera is not recognizing the SD card.
Shoot some photos with it and see if it store it in the memory card you have.
If it does, then format that card in the camera itself and do the firmware update all over again.
04-15-2010, 05:29 PM   #3
If I remember correctly 1.02 firmware adds SDHC compatability hence your camera not being able to read the card, you will need an sd card smaller than 4 gig for the camera to read the firmware.
HTH
Gary
Just read your post & noticed it says 16mb??? You did mean 16 gig??? Never seen a 16mb SD card
04-16-2010, 01:06 PM   #4
Yeah, the card I was using was ancient. I was using the Mac download, and it wouldn't work, so I ran Windows in parallels and loaded the .exe version and the firmware file was different. When I tried that, it worked fine. So if anybody ever had problems with this try the windows version.
04-17-2010, 05:48 PM   #5
GerryL's Avatar
Glad you got it figured out.
camera, card, dslr, firmware, k100d, photography
K100D Firmware Upgrade marianne718 Pentax DSLR Discussion 5 01-24-2011 09:58 PM
I need K100D firmware v. 1.00 or 1.01 zorobabel Pentax DSLR Discussion 5 05-18-2008 07:30 AM
K100D firmware axl Pentax DSLR Discussion 4 09-17-2007 11:26 PM
K100D Firmware anomaly Pentax DSLR Discussion 17 09-04-2007 07:32 AM
K100D firmware V 1.02 Bostjan Pentax DSLR Discussion 4 05-21-2007 12:57 AM
All times are GMT -7. The time now is 02:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
