04-17-2010, 09:29 AM   #1
K-7, Firmware 1.3, software bug??
I don't know if I can trust my K-7 anymore.
After 6000 pictures taken it failed on me today.
Today while shooting at the youngest son rowing race in Amsterdam, my K-7 decided that pressing the release button meant: doing a mirror lockup!
So, I missed a lot of nice shots!
Changing the lens, menu settings, taking out the battery, nothing helped, except putting the camera in green mode.
All other modes were infected.
Since I never use the green mode, that was a problem.
Finally doing a factory reset solved the problem, having me reconfig the camera for 20 minutes.
Did anybody experience the same problem before??
I'm on firmware 1.3. I cannot find a difference between the latest bin file on the Pentax site and the file I downloaded in february...
I thought, maybe a firmware update will help.
How can you see the 1.3.??? sub-numbering of the different files?
- Bert
04-17-2010, 09:34 AM   #2
QuoteOriginally posted by bymy141 Quote
Today while shooting at the youngest son rowing race in Amsterdam, my K-7 decided the pressing the release button meant: doing a mirror lockup!
Since I never user the green mode, that was a problem.
- Bert
Look at an unprocessed file with PhotoMe. Under manufacturer notes, it gives the full version file name.
Can't help you with the problem as I've never experienced it. Hope I don't either..
04-17-2010, 11:58 AM   #3
It was on 1.03.00.19, I've updated it to 1.03.00.22
I hope it does not happen again....
04-17-2010, 12:38 PM   #4
Ole
Ole's Avatar
I assume that you had not accidentally knocked the camera into Mirror Lock-up mode? It's not that hard to make that mistake in the heat of things.
Mirror Lock-up is disabled in Green mode which could explain why you were able to shoot in that mode, but not in the other modes.
04-17-2010, 07:37 PM   #5
Canada_Rockies's Avatar
- Bert
I suspect that you have the camera set to a 2 sec delay in the drive menu (up in the Fn menu). Set it to single shot, and the camera should return to what you need to do the job.
04-18-2010, 03:01 AM   #6
QuoteOriginally posted by Ole Quote
QuoteOriginally posted by Canada_Rockies Quote
Perhaps I must have accidently knocked it in Mirror Lock-up mode.
You may be right here, however, there is no way to find out.
Except for the 2 sec delay, I don't think that it was that, I should have seen that on the top display.
Thanks for the tips!
- Bert
04-18-2010, 05:52 AM   #7
Tuner571's Avatar
Yea, I would agree that you may have bumped the camera into mirror lock up mode. I too have done it before on my K20D but since I use that mode alot I knew where to go to change it. Do you know where the option is to change the camera into this mode? If you did, did you try and change it back to the normal setting. If you did this then there might be a problem, if you didn't do this you need to read up on your camera and find where this option is.
camera, dslr, file, firmware, k-7, mode, photography
K-X focus trap firmware bug? tomtor Pentax DSLR Discussion 6 11-07-2009 02:16 AM
Aperture 2.1.1 update fixes K20D firmware 1.01 bug? yetidesign Digital Processing, Software, and Printing 0 07-29-2008 12:59 PM
Latest Mac software updates fix K20D firmware 1.01 pef file problems mstahulak Digital Processing, Software, and Printing 1 07-23-2008 08:00 AM
how about those firmware/software updates generic Pentax DSLR Discussion 2 06-27-2008 05:31 AM
All times are GMT -7. The time now is 10:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
