Originally posted by Marc Sabatella So 48GB would be 4800 images. Call it 5000 and that sounds like 10 sets of cells to me. 75GB sounds like 15 sets.
I might try taking 5 sets each, start off using with the Eneloops, then use the lithiums until either a) they run out, b) you have a chance to recharge the Eneloops, or c) your trip ends. When in doubt, just take more.
These calculations sound about right using a conservative figure of 500shots/charge of eneloops - I regularly get well over 1,000 shots/charge (K100D, K-x) - my "best" being over 1,500 (K-x) - but my shooting habits may well be different.
Flash, Live View and Movies are the eaters of batteries -
if none of those are used then 500 shots/charge is a conservative figure.
I have to take it that shooting 48-75gb is unlikely to be in one single session or in a single day?
Then the number of sets of batteries is only valid if there is no chance of recharging the eneloops.
Should really count the number of shots likely in a single day - 500? 1,000?
Let's take 1,000 - this is pretty high even for being trigger happy -
then 2 fully charged sets of eneloops is likely to suffice.
Have a spare set handy and also carry a set of fresh lithium disposables for backup - ought to do it -
then even if one actually manages to deplete two sets of eneloops - probably over 1,000 shots per day(!) -
then plan on charging the two sets, so they are ready for the next day......
It's a myth that slow charging is "better" for batteries -
it's missing end of charge termination - leading to over-charge and over-heat that damages batteries.
The most recommended charge rate is actually 1/2C
- for eneloops this is 1000mA -
that's about 2 hours' charge -
just make sure to use a good reputable/reliable charger
