Originally posted by Tall Guy I have used my Super Tak 50 1.4mm with my K10 many times in the past, but I recently had to do a firmware BF adjustment (V 1.30). The BF issue was solved using my F and DA series lenses. But I finally had the chance to get out with my Taks to do some "manual" shooting. ( I use the PENTAX adapter).
The results were far from acceptable with many shots out of focus on the focal points (Looks like BF in manual focus mode??).
If any one can weigh in on this problem, I would really appreciate it. I am a little baffled as to why a focusing issue would arise when focusing manually, and in manual program mode.
If this post should be in another forum, please advise.
Thanks
Originally posted by wildlifephotog Adjusting the AF has no effect on manual focus. Manual is totally dependent on your eye, nothing else. A good split screen would make it easier.
Tall guy: I may have misunderstood your post. If you adjusted your K10D for the benefit of the AF lenses you listed then you very well affected the focus of the Tak as well.
Although wildlifephotographer is right that AF doesn't come into play and that you have to use your eyes, it does make a difference with when you see the green hexagon and even when the red center indicator lights up. If you rely on those or the focus trap method, you will get blurred shots.
I have a k10d with a katz eye prism and the lenses listed below. I went thru each and made an adjustment so that the focus indicator lights when the prism is perfectly aligned. I then made a list on paper and placed in in the side hatch where you connect the computer cable, etc. I keep my camera in the debug mode to quickly adjust the focus for each lens, including the manual focus lenses. Trust me it does make a difference. When you use a split prism, it is easy to see when the focus indicator is off. Ignoring the prism, the image looks fairly sharp due to the DOF issues Marc outlined.
Hope this helps,
Mark
