10-08-2010, 06:13 PM   #31
Wheatfield's Avatar
QuoteOriginally posted by Edvinas Quote
As far as I understand, shutter induced blur is hardware issue, isn't it?
It is. And it's unavoidable while the camera has moving parts.
It's a good idea to run a check and see what shutter speeds are to be avoided if possible.
For example, my old Super Program film camera needed to be on a 15 pound Zone VI tripod before it was fully controlled. Verticals at 1/8 and 1/15 second were particularly problematic for the one I had.
My gut feeling (I haven't practiced what I preach) is that this weakness still exists to a certain extent in the DSLR series, at around the same shutter speed range.
10-08-2010, 06:33 PM   #32
catsman50's Avatar
looks like the K-x new firmware has some decent benefits
Changes to V1.01
* Added three kinds of particular effect shooting function (Pre-set 1,2 and 3) on [Cross Processing].
* Added assignment of Cross Processing function to the green button.
* Improved accuracy of Battery Level Indicator under specific conditions and improved stability for general performance.
10-08-2010, 08:25 PM   #33
jeffshaddix's Avatar
could just be adding lens corrections for their newest lenses? Keep in mind I'm a total noob and could be way off base here.
Is there any way to tell which version of 1.10 I'm running? When I fire up my k7, it simply says 1.10. I just updated the firmware on monday because thats when I received the camera. Perhaps I was lucky enough to grab the most recent just as it came out, but I'm unclear on how to determine this exactly. Thanks for any help!
Aggrobot, Use the program PhotoMe. It's useful for looking at other metadata as well!
PhotoME - Exif, IPTC & ICC Metadata Editor
10-08-2010, 08:27 PM   #34
QuoteOriginally posted by ManuH Quote
No, the lens correction data is inside the lens chip.
It could however be fixing the focal length bug with the new Sigma 8-16mm (where anything less than 10mm becomes "--" in the exif data).
10-08-2010, 09:23 PM   #35
K-7 firmware version 1.03 added lens correction data for the smc PENTAX-FA 31mm F1.8 AL Limited, smc PENTAX-FA 43mm F1.9 Limited and smc PENTAX-FA 77mm F1.8 Limited, so it's certainly possible for this to be handled in firmware. (One would imagine less correction data is needed for a prime lens, which may be part of how this was added in firmware.)
That said, I would say there's zero chance Pentax would've added new lens correction data to the K-7 firmware without increasing the public version number, and touting the change.
10-09-2010, 11:58 AM   #36
QuoteOriginally posted by jeffshaddix Quote
Thanks for the tip!
10-09-2010, 03:08 PM   #37
Voin vahvistaa sen, hyvä ohjelma
10-09-2010, 04:30 PM   #38
Hypocorism's Avatar
Thanks for that tip Jeff. That's one mega-useful freeware utility.
.R.
11-18-2010, 03:11 AM   #39
Updated with K5 firmware...
Anyone knows the firmware number?
EDIT : it's v1.01.00.05
*ist, camera, cameras, dslr, firmwares, md5, pentax, photography, versions
People Solitary Surfer (Color and B&W versions) ismaelg Post Your Photos! 1 02-10-2010 07:13 AM
For Sale - Sold: How to select & use Pentax SLR cameras by Carl Shipman tsiklop Sold Items 0 12-26-2009 08:43 AM
Good USA repairer for Pentax P&S film cameras? ChrisPlatt Pentax Compact Cameras 8 02-16-2008 12:10 PM
Pentax Screw-mount Cameras & Lenses Matthew Roberts Pentax Film SLR Discussion 7 04-21-2007 02:53 AM
All times are GMT -7. The time now is 12:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
