How you use the modes depends on the photographer as the K10D is so customizable. But if it helps, here's what I generally use the modes for:
* - (Mode) / (Description) / (Usage)
* - Green / Full automatic (Camera Settings are locked) / Only when I'm letting a non-photographer take pictures with my camera.
* - P / Full Automatic (Camera Settings are NOT locked) / My primary shooting mode when I'm roaming around and taking shots. I set my program line to MTF, so it'll prioritize exposure to the lens' sweet spot for aperature and adjust shutterspeed. I have my Front Dial to P-shift, Rear Dial to EV-Compensation.
* - Av / Aperture Priority (You set the Aperture, the camera adjusts for other settings) / I have my front dial set to Aperture, and rear dial to EV-Compensation. I use it when I need to control the depth of field (distance that's in focus).
* - Tv / Sutterspeed Priority (Time Priority), (You set the Shutterspeed, camera adjusts other settings) / I have my front dial to Shutterspeed, Rear dial to EV-Compensation. I use it when I'm looking for a specific blurred motion effect or frozen action shot.
* - Sv / Sensitivity Priority (You set the ISO, the camera adjusts other settings) / I personally don't have much use for this mode because I find the ISO so easy to change in my other modes anyways (hold down OK, turn edial).
* - TAv / Time and Aperture priority (You set shutterspeed and aperature, the camera will adjust ISO) / Useful for taking repeated shots of the same scene where light can change slightly while controlling motion and depth of field. I have front edial for Aperture, Rear dial for Shutterspeed.
* - M / Manual Exposure / You control Aperture, Shutterspeed, and ISO (When all else fails... do it yourself)/ I used to use it primarily for long exposures before, now I find myself using it a lot more (especially for flash photography) since the green button is always around (green button resets Aperture and Shutterspeed to what the P-mode value would have been).
* - User / User Customized (Copies a Pv, Av, T, S, TAv, M mode for basic functionality, but hold a separate line of presets (different resolution, continuous shooting mode, etc adjusting settings under the User Menu will not affect other shooting modes) / This is either set to my continuous jpg mode, or a preplanned scene I know I'll arrive at (museum, inside a particular building, etc).
As I said, different photographers have different needs and will set it to do so, but you're welcome to try my settings to start until you find something you're more comfortable with.
