04-21-2010, 12:35 AM   #1
Cleaning the Sensor on K100D
After 3 years of use my sensor finally had to much dust to live with. I elected to take it to the local repair shop for cleaning. They did a great job for $39.
If you're cleaning the sensor yourself what are you using?
Thanks
04-21-2010, 12:37 AM   #2
jct us101's Avatar
The rocket blower is usually the easiest and most used way to get rid of dust, since you're never actually touching the sensor, but it's also the least effective, because you're just blowing air on the sensor, which doesn't always get rid of all the dust. The only way that I have really heard of other than that though is the wet cleaning method, which I would be very hesitant to use myself since I've never cleaned a sensor before.
04-21-2010, 01:25 AM   #3
I used to bring in my K10D to the local camera shop who would clean it for € 25.
Until half a year ago there were a few specs on the sensor that they could not get rid off.
The shop uses a special high pressure but absolute clean air pump, not touching the sensor.
They returned the camera without cost, but with still some specs on the sensor.
I bought a wet swipe cleaning set, watched the video on the Internet and gave it a go. And it worked extremely well.
The most important issue with swiping is the possibility of scratching with small sand particles.
Since the sensor was before treated with high pressure air, I thought it would be no problem.
Actually the procedure was simpler and easier then I thought it would be.
I read a post of somebody buying mascara brushes cleaning them with soft soap and using them to dry swipe his sensors.
Since it uses a soft brush scratching is less probable.
I have not tried it yet but found it a great idea.
If you decide to swipe, I advise you to first use a rocket blower to make sure to remove all larger (sand) particles.
- Bert
04-21-2010, 08:28 AM   #4
rparmar's Avatar
I use the Arctic Butterfly, which is an electrostatic brush. Powered by a battery, you turn it on for a bit to get a charge going and then turn off the brush. It can then be softly dragged across the sensor and the charge helps pull off dust with no pressure required. I have found that this works perfectly! Though I change lenses often I only need to do this every six months or so with my K20D, but my K100D Super needed a lot more dust removal care for some reason.
The great thing about the Arctic Butterfly is it fits anywhere in the camera bag and requires no fluids or other mess. It can go on flights no problem.
The website might have several models and different kits but just get the cheapest one. It does the same job.
I do not use a blower as this might simply remove particles from one place and send them somewhere even more obscure.
04-21-2010, 09:14 AM   #5
I had an arctic butterfly and couldn't make it do anything more than slide the dust around. I'm sure it was user error. The guy who bought it from me seems to be happy with it (though he still needs to contact me).. THE best thing I've ever used and swear by today, is the Pentax O-ICK1 cleaning kit. The blower, the AB, the Sensor Swabs, never got my sensor as clean as the cleaning kit. Yeah, it's a sticky lollipop looking gizmo with a pad of 'special' cleaning paper but I can't argue with what works for me.
04-21-2010, 09:52 AM   #6
Ember.'s Avatar
How much I have heard
Reidl Imaging The Digital camera Cleaing Expert
VisibleDust -- DSLR Sensor Cleaning
these kits are good for cleaning
04-21-2010, 01:32 PM   #7
I use an Arctic Butterfly as well. Absolutely spot on
er
off
04-21-2010, 02:16 PM   #8
Tuner571's Avatar
I use the rocket blower for the really tough stuff; it works very well and normally removes the dust in three easy blows. I have yet to have a dust particle that I could not remove from my sensor. There have been times that I was concerned, but a few more blasts of air got them lose.
04-21-2010, 05:16 PM   #9
GerryL's Avatar
I use the rocket blower first then wipe the sensor with lens cloth that is new or very-very clean.
I got one dust that was very hard to remove by blowing alone with the "wiping" thing.
I did not wipe down the whole sensor though, just the spot were the suspected dust was.
04-21-2010, 07:03 PM   #10
Chock another user up for the Arctic Butterfly! Love it to bits- I used to wet clean but those sensor cleaner swabs are EXPENSIVE (the fluid isn't really an issue)- for the same price as 2 sets of swabs I bought the cheapest Arctic Butterfly (as rparmar suggested).
I have a K100DS: really seems to be a dust magnet. Not sure why. So, the AB has been saving me tons in terms of cleaning costs! 3 charges/swipes later, and all the nasty blobs are gone gone gone... :-)
04-21-2010, 08:19 PM   #11
cheers's Avatar
i've used a rocket blower with great success. just turn the camera with the mount pointed down so that any dislodged dust particles tend to float downward. repeat several times, move the end of the blower so it's not blowing in the same location, then blow some more. let it rest in with the mount down, with the body cap on, then blow some more. you'll have a clean sensor with no risk of scratching.
04-23-2010, 11:35 AM   #12
blow job on camera sensor
That's the way to get your sensor to come clean.
I use a homemade blower - a plastic air pump with a long plastic tube and nozzle, the type that looks like a bellows - you squeeze it to inflate air mattresses etc.
I washed it out, let it dry, reassembled it and glued a piece of synthetic cloth over the intake valve, to act as a filter. The pump is foot operated and the nozzle is directed into the camera, held upside down. Clean air is sucked in through the filter, clean air is blown out at relatively high speed and much more volume than a Rocket blower or any other commercial blower.
Two blasts and the sensor was clean as an operating theatre.
Rubber blowers will deteriorate eventually and spit out tiny pieces of sticky rubber. Be especially careful of the pill shaped rubber blowers with brushes on the end - these are made to dust off lenses, not sensors.
Best thing I've made all year.
camera, dslr, photography, sensor
Automatic Sensor Cleaning in k100d Super and k10d superfuzzy Pentax DSLR Discussion 3 11-19-2007 04:18 PM
K100D Sensor Cleaning Jimsi777 Photographic Technique 2 11-16-2007 01:19 PM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
Sensor cleaning > Sensor Swab > void warranty? Twinky Pentax DSLR Discussion 2 07-28-2007 01:10 AM
Weird Sound of K100D (K10D 2?) in B/Sensor Cleaning Mode RiceHigh Pentax DSLR Discussion 13 01-05-2007 07:01 AM
All times are GMT -7. The time now is 02:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
