Originally posted by conradcjc Bert,
How do you like that 60-250mm? Are the pictures amazing? Is it good for the outdoor stuff I want to do as listed above.
Do you know if you can put a teleconverter on the Pentax 300mm? If so which one works the best?
Thanks
Chuck
Hi Chuck, the 60-250mm is great. I went to the shop first a took a large amount of test shots with both the 60-250 and 55-300 and did true pixel peeping at home.
I decided to take both.
The 55-300 is surprisingly good considering the cost.
The 60-250 is definitely better at the long end, very sharp, also in the corners. Its bokeh is superb.
Both lenses will handle the TC's I have in daylight, however the 55-300 suffers more in IQ than the 60-250.
Focusing in low light (without TC) with the 60-250mm is problem at all.
See samples below.
I travel a lot, also in rainy and dusty environments.
The 55-300mm is great for hiking and long walks considering its weigth and size, that is the sole reason I've bougth it for.
The 60-250mm (optional with TC) is great for wildlife / safari and harsh environments.
The Pentax 1.7x TC is (by the way) available new through the Japanese amazone site.
Amazon.co.jp: pentax 1.7x - ‰Ć“d&ƒJƒƒ‰: ‰Ć“dEƒJƒƒ‰
Some low light DA* 60-250mm examples:
DA* 60-250mm with Kenko 1.5Tx TC [AF works fine during daytime]
A few 55-300mm shots from last weekend:
With Pentax 1.7x TC:
Without TC:
I hope this helped.
- Bert
